Hi.
Since the Institue I’m working in “updated” their iMX7 chips, somehow after using modprobe bcmdhd the system doesn’t want to connect to the network.
Here’s the output:
root@pico-imx7:~# modprobe bcmdhd
dhd_module_init in
wifi_plat_dev_drv_probe no GPIO for OOB in device tree.
wifi_plat_dev_drv_probe continue with non-OOB mode.
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
mmc1: new high speed SDIO card at address 0001
imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
imx-sgtl5000 sound: snd_soc_register_card failed (-517)
F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
wifi_platform_get_mac_addr
fw path is /lib/firmware/brcm/fw_bcm4339a0_ag.bin
nvram_path is /lib/firmware/brcm/nvram_ap6335.txt
CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211)
wl_create_event_handler(): thread:wl_event_handler:29f started
CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0x88f2143c
dhd_attach(): thread:dhd_watchdog_thread:2a0 started
dhd_attach(): thread:dhd_dpc:2a1 started
dhd_attach(): thread:dhd_rxf:2a2 started
dhd_deferred_work_init: work queue initialized
random: nonblocking pool is initialized
dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
Firmware up: op_mode=0x0005, MAC=28:ed:e0:0e:fd:de
dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
Firmware version = wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
dhd_wlfc_init(): successfully enabled bdcv2 tlv signaling, 79
dhd_wlfc_init(): wlfc_mode=0x0, ret=-23
dhd_interworking_enable: failed to set WNM info, ret=-23
Dongle Host Driver, version 1.141.92 (r)
Compiled in drivers/net/wireless/bcmdhd
Register interface [wlan0] MAC: 28:ed:e0:0e:fd:de
root@pico-imx7:~# imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
CFG80211-ERROR) wl_cfg80211_connect : Connecting withe8:de:27:96:b2:a9 channel (6) ssid "TP-LINK_AP_96B2A9", len (17)
wl_bss_connect_done succeeded with e8:de:27:96:b2:a9
After that when using ifconfig wlan0, I get the following:
root@pico-imx7:~# ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 28:ed:e0:0e:fd:de
inet addr:130.75.43.226 Bcast:130.75.43.255 Mask:255.255.255.0
inet6 addr: fe80::2aed:e0ff:fe0e:fdde/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:330 errors:0 dropped:0 overruns:0 frame:0
TX packets:68 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:41033 (40.0 KiB) TX bytes:10284 (10.0 KiB)
Using the old Chip, I can’t ping to any Ip and giving it a static Ip address doesn’t solve anything (requesting dhcp takes me to an infinite loop).
If I connect it to the laptop, I can use putty, but the “modprobe g_mass_storage” command is also buggy (bo error, but also no recognition of the partition).
Do I need to update the firmware? The one in use is fw_bcm4339a0_ag.bin
Both Chips are Colibri PICO-IMX7D 1 GiB and both have the same antenna attached.
With kind regards,
Mateusz
