Dear Support Team,
i am testing ACA V2.0B module with Colibri iMX6DL V1.1A and Colibri Eva Board V3.2B, the ACA is well connected via X22 on Eva Board, also have changed the fdt_file to imx6dl-colibri-cam-eval-v3.dtb in imx6 uboot, and the linux version on imx6 is offcial LXDE demo image v2.8. The gstreamer pipeline always give below error message and can’t capture video stream from ACA.
root@colibri-imx6:~# gst-launch-1.0 imxv4l2videosrc ! imxipuvideosink use-vsync=true
Setting pipeline to PAUSED ...
[ 574.150387] mxc_sdc_fb fb@0: 1024x768 h_sync,r,l: 104,48,152 v_sync,l,u: 4,3,23 pixclock=63500000 Hz
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 584.793066] ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
ERROR: from element /GstPipeline:pipeline0/GstImxV4l2VideoSrc:imxv4l2videosrc0: Internal data stream error.
Additional debug info:
../../../../git/libs/gst/base/gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstImxV4l2VideoSrc:imxv4l2videosrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:10.170007334
Setting pipeline to READY ...
Setting pipeline to NULL ...
[ 585.316179] mxc_sdc_fb fb@0: 1024x768 h_sync,r,l: 104,48,152 v_sync,l,u: 4,3,23 pixclock=63500000 Hz
Freeing pipeline ...
BTW, i also have tried several other pipelines like autovideosrc ! autovdeosink, the error is same. and with the same ACA module setup, i connect it to Apalis imx6 and Apalis Eva Board, it works well out of box.
Could you help check if there is same issue and any clue or solution?
Thanks a lot!
Simon
