I am following the article Distro Boot | Toradex Developer Center to load Toradex Easy Installer on my Colibri iMX7D. However, when I run the command:
# run distro_bootcmd,
the loading fails. The output is shown below.
I am unsure where the problem is. I have compiled the image using the guide: High performance, low power Embedded Computing Systems | Toradex Developer Center.
I am using the Viola carrier board, with console connected through serial (i.e. no screen attached).
Output:
Colibri iMX7 # run distro_bootcmd
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
2173 bytes read in 14 ms (151.4 KiB/s)
## Executing script at 87000000
445 bytes read in 89 ms (4.9 KiB/s)
** File not found /boot/ostree/torizon-82d4156fb4e2bf886241b9d3269f47e12ba2c3a2470529367fda9de4c7e1a5eb/devicetree- **
7528960 bytes read in 277 ms (25.9 MiB/s)
2809234 bytes read in 155 ms (17.3 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x72e200 ]
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
mmc1 is current device
Scanning mmc 1:1...
reading /boot.scr
464 bytes read in 12 ms (37.1 KiB/s)
reading /tezi.itb
21374744 bytes read in 935 ms (21.8 MiB/s)
## Loading kernel from FIT Image at 82100000 ...
Using 'config@imx7d-emmc' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000dc
Data Size: 5308472 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 910fc4bfe6325ca943e1af0824a15957
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x826101fc
Data Size: 15929344 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: bf0a406d6fa572c48f601023ca980bd2
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@imx7d-emmc' fdt subimage
Description: Colibri iMX7 Dual 1GB eMMC Device Tree
Type: Flat Device Tree
Data Start: 0x83557184
Data Size: 45372 Bytes = 44.3 KiB
Architecture: ARM
Hash algo: md5
Hash value: b34140d2c5400aef8309a51bb7486030
Booting using the fdt blob at 0x83557184
Loading Kernel Image ... OK
Loading Device Tree to 8fff1000, end 8ffff13b ... OK
Starting kernel ...
[ 1.000304] CPU1: failed to come online
[ 1.296782] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
[ 1.467665] caam 30900000.caam: failed to acquire DECO 0
[ 1.504300] caam 30900000.caam: failed to acquire DECO 0
[ 1.537008] caam 30900000.caam: failed to acquire DECO 0
[ 1.570746] caam 30900000.caam: failed to acquire DECO 0
[ 1.607876] caam 30900000.caam: failed to acquire DECO 0
[ 1.642015] caam 30900000.caam: failed to acquire DECO 0
[ 1.677144] caam 30900000.caam: failed to acquire DECO 0
[ 1.714246] caam 30900000.caam: failed to acquire DECO 0
[ 1.748320] caam 30900000.caam: failed to acquire DECO 0
[ 1.782398] caam 30900000.caam: failed to acquire DECO 0
[ 1.816468] caam 30900000.caam: failed to acquire DECO 0
[ 1.850577] caam 30900000.caam: failed to acquire DECO 0
[ 1.884650] caam 30900000.caam: failed to acquire DECO 0
[ 1.918731] caam 30900000.caam: failed to acquire DECO 0
[ 1.952802] caam 30900000.caam: failed to acquire DECO 0
[ 1.986873] caam 30900000.caam: failed to acquire DECO 0
[ 2.019979] caam 30900000.caam: failed to acquire DECO 0
[ 2.055088] caam 30900000.caam: failed to acquire DECO 0
[ 2.090198] caam 30900000.caam: failed to acquire DECO 0
[ 2.122252] caam 30900000.caam: failed to acquire DECO 0
[ 2.154320] caam 30900000.caam: failed to acquire DECO 0
[ 2.186392] caam 30900000.caam: failed to acquire DECO 0
[ 2.218496] caam 30900000.caam: failed to acquire DECO 0
[ 2.251590] caam 30900000.caam: failed to acquire DECO 0
[ 2.256915] caam 30900000.caam: failed to instantiate RNG
[ 2.262623] Trying to vfree() nonexistent vm area (b4063000)
[ 2.270158] Unable to handle kernel NULL pointer dereference at virtual address 00000004
[ 2.278259] pgd = 80004000
[ 2.281033] [00000004] *pgd=00000000
[ 2.284638] Internal error: Oops: 805 [#1] SMP ARM
[ 2.289435] Modules linked in:
[ 2.292517] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.1.44-1.8.0+gf3637519a6aa #1
[ 2.301393] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 2.307147] task: b407c000 ti: b4062000 task.ti: b4062000
[ 2.312555] PC is at caam_sm_startup+0x8c/0x3cc
[ 2.317094] LR is at device_add+0x150/0x568
[ 2.321286] pc : [<804c03dc>] lr : [<8037504c>] psr: a0000113
[ 2.321286] sp : b4063ec8 ip : 00000000 fp : 00000000
[ 2.332770] r10: 00000000 r9 : 808f4624 r8 : 00000000
[ 2.338002] r7 : 808dab9c r6 : b779d838 r5 : b4176a10 r4 : b4211840
[ 2.344536] r3 : b5386400 r2 : b5386410 r1 : 00000000 r0 : b5386400
[ 2.351072] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 2.358388] Control: 10c5387d Table: 8000406a DAC: 00000015
[ 2.364140] Process swapper/0 (pid: 1, stack limit = 0xb4062210)
[ 2.370154] Stack: (0xb4063ec8 to 0xb4064000)
[ 2.374522] 3ec0: 804d476c 808dab9c 00000000 b5386400 b4176a10 8090b920
[ 2.382711] 3ee0: 8090b920 b5370b00 808dab9c 00000000 808f4624 00000007 00000000 808dabec
[ 2.390899] 3f00: 8090b920 80009678 80911c64 808f4600 00000000 80141aac 80911d00 b4113700
[ 2.399087] 3f20: 00000000 809105c4 80885748 000000ac b7fffb3f 800453a4 00000000 80822284
[ 2.407276] 3f40: 00000006 00000006 b7fffb4a 807d11a4 809105ac 000000ac 80951000 000000ac
[ 2.415464] 3f60: 80951000 80951000 808fe0e4 808f461c 808f4624 808b4db8 00000006 00000006
[ 2.423652] 3f80: 808b45a0 80654750 00000000 80654750 00000000 00000000 00000000 00000000
[ 2.431841] 3fa0: 00000000 80654758 00000000 8000f3a8 00000000 00000000 00000000 00000000
[ 2.440029] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.448217] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff 80020000
[ 2.456413] [<804c03dc>] (caam_sm_startup) from [<808dabec>] (caam_sm_init+0x50/0x58)
[ 2.464259] [<808dabec>] (caam_sm_init) from [<80009678>] (do_one_initcall+0x8c/0x1d0)
[ 2.472190] [<80009678>] (do_one_initcall) from [<808b4db8>] (kernel_init_freeable+0x144/0x1d4)
[ 2.480904] [<808b4db8>] (kernel_init_freeable) from [<80654758>] (kernel_init+0x8/0xe8)
[ 2.489009] [<80654758>] (kernel_init) from [<8000f3a8>] (ret_from_fork+0x14/0x2c)
[ 2.496590] Code: e59d300c e2832010 e5843008 e5834068 (e58a2004)
[ 2.502733] ---[ end trace f68425b0a7de93ab ]---
[ 2.507376] mmc0: MAN_BKOPS_EN bit is not set
[ 2.511837] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.511837]
[ 2.520984] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
