Many serial COM ports for usb are not detected by the Toradex Colibri VF61.
Knowing that it’s were working before.
any suggestions about this problem
BR,
Rawia
BR,
Rawia
Dear @rfrikha
Our default Windows CE does not include any drivers for USB-to-UART converters. I assume you had such drivers installed on your system where it was working.
Regards, Andy
Dear Andy,
I reinstalled the drivers for FT230XQ but nothing is changed. It still not working.
You think it’s a hardware problem in this case!??
BR,
Rawia
Dear @rfrikha
It could be both a driver or hardware issue. To test the hardware:
If both tests above are successful, your hardware is most probably ok.
Regards, Andy
