I have a question how is the Update Tool working. I try to install CF2.0 then CF3.5 setup screen resolution add some drivers then save register SaveReg tool next open Update Tool select Backup → Registry, save to file. I think whole register should be save it, I’m right? Then reboot VF61 go to Update Tool and select Update then select my backup file, when is loaded run SaveReg and reboot VF61.
Is not working after reboot is look like register is not save it or loaded.
