I’m working on a colibri-imx6ull. Setting up the usb-otg as rndis network device works fine and there is even a dhcpd running. My problem is, that I can’ t change the network address. I found this in the documentaton:
ifconfig usb0 192.168.100.2
Okay, the address changes, but after rebooting, the address falls back to 192.168.11.1. And the dhcpd always gives leases in the network 192.168.11.0/24
Well, I just want to configure it. I want to have a address different to 192.168.x.x just to see the difference. And to change it in the case the 192.168.11.0 net is already used on the PC which will be connected.
