Hi, we are using the Toradex BSP as base for our own distribution. After upgrading to LinuxImage-3.0 with the 2019.07 U-boot USB reading broke on Apalis iMX6. Are there any known bugs related to that?
I attached an u-boot log
U-Boot 2019.07-3.0.2+ge1cbe8c (Nov 07 2019 - 15:44:12 +0000)
CPU: Freescale i.MX6Q rev1.5 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 39C
Reset cause: WDOG
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184994
Net: using PHY at 7
FEC [PRIME]
Apalis iMX6 # usb start
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices... 3 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
Apalis iMX6 # load usb 0:1 ${loadaddr} flash_mmc.img
data abort
pc : [<8efb3096>] lr : [<8efb2b19>]
reloc pc : [<17834096>] lr : [<17833b19>]
sp : 8cf73d80 ip : 00000003 fp : 00000000
r10: 8cf83330 r9 : 8cf7eea8 r8 : 00000001
r7 : 8cf833f8 r6 : 8bf72040 r5 : 8cf73da8 r4 : 00000020
r3 : 00000066 r2 : 8bf720a3 r1 : 8cf83464 r0 : 8bf7209f
Flags: nzCv IRQs off FIQs off Mode SVC_32
Code: 4630ff4d 81f0e8bd e7d84606 bf082b2f (f822235c)
Resetting CPU ...
resetting ...
Industrial temperature grade DDR3 timings.
Trying to boot from MMC1
Reset cause: WDOG
Anton
