I have a serial peripheral that I have been able to use successfully on UART3 in FreeRTOS on the M4, but when I try to use it on UART7 I get the following behavior:
- The Rx interrupt is triggered normally
- The Rx buffer contains only 0’s (data is expected; it is non-zero
when using the UART3)
The ELF is loaded on the M4 using a Segger JLink debugger from Eclipse, so Linux is not yet started on the A7.
Here is the UART7 configuration, using DTE mode as recommended (excerpts from the pin_mux.c, hardware_init.c and uart_interrupt.c files):
RDC_SetPdapAccess(RDC, rdcPdapUart7, 3 << (BOARD_DOMAIN_ID * 2), false, false);
CCM_UpdateRoot(CCM, ccmRootUart7, ccmRootmuxUartOsc24m, 0, 0);
CCM_EnableRoot(CCM, ccmRootUart7);
CCM_ControlGate(CCM, ccmCcgrGateUart7, ccmClockNeededRunWait);
IOMUXC_SW_MUX_CTL_PAD_SD1_DATA1 = IOMUXC_SW_MUX_CTL_PAD_SD1_DATA1_MUX_MODE(2);
IOMUXC_SW_MUX_CTL_PAD_EPDC_DATA12 = IOMUXC_SW_MUX_CTL_PAD_EPDC_DATA12_MUX_MODE(3);
IOMUXC_SW_PAD_CTL_PAD_SD1_DATA1 = IOMUXC_SW_PAD_CTL_PAD_SD1_DATA1_PE_MASK |
IOMUXC_SW_PAD_CTL_PAD_SD1_DATA1_PS(3) |
IOMUXC_SW_PAD_CTL_PAD_SD1_DATA1_HYS_MASK |
IOMUXC_SW_PAD_CTL_PAD_SD1_DATA1_DSE(0);
IOMUXC_SW_PAD_CTL_PAD_EPDC_DATA12 = IOMUXC_SW_PAD_CTL_PAD_EPDC_DATA12_PE_MASK |
IOMUXC_SW_PAD_CTL_PAD_EPDC_DATA12_PS(3) |
IOMUXC_SW_PAD_CTL_PAD_EPDC_DATA12_HYS_MASK |
IOMUXC_SW_PAD_CTL_PAD_EPDC_DATA12_DSE(0);
IOMUXC_UART7_RX_DATA_SELECT_INPUT = IOMUXC_UART7_RX_DATA_SELECT_INPUT_DAISY(5);
uart_init_config_t uart_7_initConfig = {
.baudRate = 115200u,
.wordLength = uartWordLength8Bits,
.stopBitNum = uartStopBitNumOne,
.parity = uartParityDisable,
.direction = uartDirectionTxRx
// Get current module clock frequency.
uart_7_initConfig.clockRate = get_uart_clock_freq(UART7);
/* Initialise UART baud rate, bit count, parity, stop bit and direction. */
UART_Init(UART7, &uart_7_initConfig);
UART_SetModemMode(UART7, uartModemModeDte);
// UART_SetInvertCmd(UART7, uartDirectionRx, 1);
// Disable IR and RS-485 9 bit modes
UART_SetIrDACmd(UART7, false);
UART_SetMultidropMode(UART7, false);
UART_SetRtsFlowCtrlCmd(UART7, 0);
UART_SetCtsFlowCtrlCmd(UART7, 0);
/* Set UART Interrupt priority */
NVIC_SetPriority(UART7_IRQn, 5);
UART_SetIntCmd(UART7, uartIntRxReady, true);
UART_SetIntCmd(UART7, uartIntRxDataReady, false);
UART_SetRxFifoWatermark(UART7, ALT_FIFO_LEN);
/* Call core API to enable the IRQ. */
NVIC_EnableIRQ(UART7_IRQn);
/* Finally, enable the UART module */
UART_Enable(UART7);
I had a similar issue on UART5. The only difference I can see with the upper UARTs is the fact that they do not have “native” pads; however since the interrupt is triggered I conclude that the pin mux is correct. Is there a missing configuration step for the upper UARTs to work?
Thanks!
