Hi team,
Testing the WiFi for a customer, I’m having some issues that I hope you can help me with:
- I believe by default, our BSP adds both
mlan
anduap
interfaces whenever we start the WiFi, and that generates 2 different hashes inconnmanctl
almost identical, however one of them try to connect to the uap (failing) while the other works when using theconnect
command, a bit annoying. I’ve documented that here, but if you could provide some more info on the topic, as well as how can we disable the uap0 interface by default (usingifconfig uap0 down
works until it is wifi is scanned again), appreciated. Also, not sure in what cases the uap0 is used so any more info in the topic is appreciated (I’ll try to update the documentation then). - Is there anyway to get the both WiFi and the Ethernet automatically connected? I’ve managed to autoconnect to the WiFi if I don’t have an Ethernet cable, but if the Ethernet is connected when restarting, only the Ethernet is connected. If I disconnect the Ethernet, then it automatically connects but customer needs both at the same time. For now, using the
connect
command is the only way we could manage to get both working at the same time, but we want to remove that step. I’ve tried with"AutoConnect = True"
, but there doesn’t seem to have any difference.
Thanks and regards,
Alvaro.
