Cross compile VLC for Apalis ARMv7
Hi Team,
I would like to cross compile the ffmpeg and VLC. I can able to cross compile ffmpeg using toolchain Configure Toolchain - Apalis iMX6.
But I couldn’t cross compile the VLC using this tool chain. I need support on VLC cross compile for ARM architecture.
Thanks,
Paramesh
HI @Parameshwaran
The provided Toolchain is just an example for our regular Bsp release. If you need to compile your custom application, then you should also create a custom Toolchain as described here.
Hi Jaski,
Thanks for the information.
Paramesh
You are welcome.
Hi Jaski,
I’m not able to create a custom toolchain using that link. Can you please help me to build it
Paramesh
What errors are you getting? Could you provide a error log in text format? Thanks
