Unable to execute jar file on toradex linux
Hello Guys,
Recently we bought Colibiri IM6DL 512MB for our company.Our customer has given java jar file and he want to execute particular Jar on this device.When i try to execute jar file in Toradex Linux i am getting error “could not find or load main class”.
I have installed jdk1.8 as per our customer request on Linux,
I am new to java and Linux and i have attached jar file.link text
Hi @vikramh93 and Welcome to the Toradex Community!
Could you provide the version of the Hardware and Software of your module?
Which command did you use to launch the jar file?
I have installed jdk1.8 as per our customer request on Linux.
How did you install jdk 1.8?
Hello @jaski.tx ,
I have installed Toradex Linux embedded through easy installer and java jdk1.8.0_231 manually by using update-alternatives --install command by using below guide link text
I am using java -jar SampeApp.jar command to execute,
Module: Col IMX6Dl 512MB IT
Hi
Thanks for your Input. You need to install Java for Arm.
I have installed Linux ARM 32 Hard Float ABI version in java. To verify i have used java -version command to see output.
Is it possible to change OS from toradex Linux to torizon OS? Previously i was able to change OS from wince to Linux by using easy installed,now i am having difficulty to change OS.
HI @vikramh93
Yes, it’s possible by using Toradex Easy Installer. Which difficulties are you having?
Could you share some error log?
Hello @jaski.tx ,
Thanks for the help.I was able to install open jdk 11 and jar got executed.
