Hi
I wanna disable serial console(ttyS0 on X22) boot loader on ready to use L4T to use ttyS0 in my application as ordinary serial port. i read this article
but it seems this article describe it during linux built process
and not applicable for downloadable ready to use L4T(UBUNTU 14.04)
what should i do in this case ?
HI @toradexvision
How many UART Ports do you need for your application?
Why cannot you use the other UART Ports?
What about a USB to UART Converter?
but it seems this article describe it during linux built process and not applicable for downloadable ready to use L4T(UBUNTU 14.04) what should i do in this case ?
In the default Bsp, this port is used for the console output. If you want to change this, then need to follow this.
Addtionally, if you also want to disable the console also in U-Boot, then you will need to build a custom U-Boot.
Hi Jaski
i need 4 serial port in my application
i wanna use /dev/ttyS0 , /dev/ttyTHS1 , /dev/ttyTHS2, /dev/ttyTHS3
and on /dev/ttyTHS3 i use UART to RS232 converter
is there any other options exist on ixora for use as RS232 or UART?
and perhaps you know i try to install mpci card (EMP2 X403) for add 4 more port .
but unfortunately I still couldn’t do it .
HI
Yes, use an USB to UART Converter.
and perhaps you know i try to install mpci card (EMP2 X403) for add 4 more port . but unfortunately I still couldn’t do it .
Yeah, I will look into this.
Hi Jaski
according to your above link to disable serial boot loader on ttyS0 in Ubuntu 14.04
i have problem:
root@tegra-ubuntu:/home/ubuntu/#apt-get install u-boot-tools
root@tegra-ubuntu:/home/ubuntu/#fw_setenv console null
cannot parse config file:no such file or directory
Error: environment not initialized
it seems not work for ready to use L4T in your site.
Hi
The Problem is on JetPack/Ubuntu side. You can stop in U-Boot and disable the console.
