the colibri T20 stopped booting the OS, I was running Linux(angstrom) on it. I tried to reinstall the OS, but could’t access the bootloader or recovery mode.
HI @ViniciusLM
Could you provide the software version of your module?
What did you do to get to the recovery mode?
Hi @jaski.tx I’m not sure about the OS version, i didn’t made the flash of the image, but i guess it is the LXDE 2.8.6. To enter the recovery mode I tried to boot on with the jumper in the JP1 connectors.
Thanks for the information.
Did you connect the Iris Carrier Board to the Development using USB A to micro USB cable as explained here?
Further you need to follow these instructions to load U-Boot in the RAM of the SOM, so that you install the image of your choice on the module.
