Need Angstrom kernel 4.9.166-2.8.6 source code
Hello
I download and install Angstrom 2.8b6 SDK and image.
Now i need Angstrom kernel 4.9.166-2.8.6 source code. download, compile and install other kernel version from toradex git but X server fail. ( i use angstrom config from /proc/config.gz).
thanks a lot
HI @Em1398
The source code of the kernel in OpenSource. Have a look at this link, please?
Which software did you install?
Could you provide an error log in text format?
Thanks and best regards,
I download viv gpu from freescale git and replace with kernel viv gpu.
recompile and now everything is ok.
Solved
Which version of viv gpu did you use?
One should really just follow the following article on our developer website:
git clone from http://git.toradex.com with tag related to your Module.
for example for colibri-imx6 clone tag “Colibri-iMX6_LXDE-Image_2.8b6.184-20190401”
