GIGABIT ethernet speed issue
I am using Aplis iMX6 1GB IT it contains a GIGABIT ethernet port but when i am trying to transfer files(.txt) to my win10 system(1 Gpbs ethernet enabled) using windows utility tool “winscp” and CAT-6 ethernet cable the maximum speed of 11 MBps is only attained. I am expecting speed to be at least 80 to 90 MBps.
HI @rajat7693
Could you provide the version of the hardware (including carrier board) and software of your module?
Have you done some tests using ipfer3?
@jaski.tx
Carrier Board : My Apalis Evaluation Board,
SOM board : Apalis iMX6,
Operating System: The Ångström Distribution v2017.12,
Architecture: arm
My Aplis board is directly connected to My Windows System over CAT6 cable
My iperf3 result :
apalis-imx6:~# iperf3 -c 192.168.1.5
Connecting to host 192.168.1.5, port 5201
[  5] local 192.168.1.1 port 48942 connected to 192.168.1.5 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  11.3 MBytes  94.9 Mbits/sec    0    121 KBytes
[  5]   1.00-2.00   sec  11.0 MBytes  92.5 Mbits/sec    0    121 KBytes
[  5]   2.00-3.00   sec  11.0 MBytes  92.5 Mbits/sec    0    121 KBytes
[  5]   3.00-4.00   sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   4.00-5.00   sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   5.00-6.00   sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   6.00-7.00   sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   7.00-8.00   sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   8.00-9.00   sec  11.1 MBytes  93.0 Mbits/sec    0    127 KBytes
[  5]   9.00-10.00  sec  11.0 MBytes  92.5 Mbits/sec    0    127 KBytes
[  5]   0.00-10.00  sec   111 MBytes  92.8 Mbits/sec    0             sender
[  5]   0.00-10.00  sec   110 MBytes  92.5 Mbits/sec                  receiver
@jaski.tx Please help to resolve issue
I tested on my side and I could easily reach up to a speed of 402Mb/s.
root@apalis-imx6:~# iperf3 -c 192.168.10.1
Connecting to host 192.168.10.1, port 5201
[  5] local 192.168.10.172 port 45740 connected to 192.168.10.1 port 5201
[  5]   0.00-1.00   sec  48.7 MBytes   408 Mbits/sec    0    273 KBytes
[  5]   1.00-2.00   sec  48.2 MBytes   404 Mbits/sec    0    314 KBytes
[  5]   2.00-3.00   sec  48.1 MBytes   403 Mbits/sec    0    328 KBytes
[  5]   3.00-4.00   sec  48.1 MBytes   404 Mbits/sec    0    345 KBytes
[  5]   4.00-5.00   sec  48.0 MBytes   403 Mbits/sec    0    361 KBytes
[  5]   5.00-6.00   sec  48.0 MBytes   403 Mbits/sec    0    361 KBytes
[  5]   6.00-7.00   sec  48.1 MBytes   403 Mbits/sec    0    376 KBytes
[  5]   7.00-8.00   sec  47.7 MBytes   401 Mbits/sec    0    376 KBytes
[  5]   8.00-9.00   sec  47.9 MBytes   402 Mbits/sec    0    376 KBytes
[  5]   9.00-10.00  sec  47.8 MBytes   401 Mbits/sec    0    376 KBytes
[  5]   0.00-10.00  sec   481 MBytes   403 Mbits/sec    0             sender
[  5]   0.00-10.00  sec   480 MBytes   403 Mbits/sec                  receiver
iperf Done.
@jaski.tx made few changes got same results as mentioned by you,but still copying speed does not crosses 11 MBps.Inspite of Bitrate : 408 Mbits/sec
What did you change?
Are you using the regular Bsp 2.8b6 image?
@jaski.tx
I am using BSP 2.8b6 image
Apalis-iMX6_LXDE-Image 2.8b6.184 20190401
Thanks for the Information.
Are you sure that your host features a 1GBit Ethernet?
Could you provide the details (model, OS, …) of your host?
@jaski.tx
I tried host to similar host connection and achieved 90MBps speed with same data.
I am sure my host has gigabit ethernet.
@jaski.tx i am on time constraint please help to resolve the issue
Hi
Could you share the output of ethtool eth0 on SoM?
Thanks and best regards,
@jaski.tx
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 7
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
Hi @rajat7693
Thanks for the information. This looks fine.
Are you trying to copy from Apalis iMX6 to your host or vice-versa?
Is the transfer speed in both directions the same?
@jaski.tx I am trying copy from Apalis iMX6 to host machine
Yes , transfer speed in both directions the same.
Tried FIlezilla and scp but results are same(max 11MBps)
@jaski.tx i am in a desperate need for help.
Could you please provide more information?
  • You said " made few changes got same results as mentioned by you" What did you change ?
  • What exactly command line you are using to copy files?
  • Can you connect another desktop or laptop instead of Apalis and run a tests?
  • Are you connected through network switch?
  • Did you try to use another switch and network cables?
@alex.tx
  • “made few changes” i followed the article Gigabit performance on Apalis iMX6Q - Technical Support - Toradex Community and used command ethtool -A eth0 rx on tx on and got result as mentioned above
  • i am using mRemoteNG to ssh my Aplis iMX6 and using SCP command to copy files to my remote system
  • I also tried different systems with gigabit ethernet and got copying result over 90Mbps with same files(two windows system)
  • I tried with and without network switch (b/w windows host and Aplis).And in actual scenario i can not use switch between host and Aplis
  • Tried 2 diff cables CAT 5E ,6
  • also tried using DHCP server when connecting directly(No switch)
@alex.tx @jaski.tx i can provide a remote access for faster diagnostics as i am on time constraint.
Could you try to copy files some different way? scp is encrypting data and it may decrease a performance.
