I am trying to put together a prototype imaging system using the iMX8QM and a custom image sensor, the Aptina AR1820HS. I understand there is no driver for the sensor currently in the OS build.
Questions:
- I found this driver in a previous fork: drivers/media/video/ar1820.c - pub/scm/linux/kernel/git/jic23/parrot - Git at Google, Is it possible to integrate this driver into the existing Yocto LinuxImage3.0 build?
- If the driver is not easily integrated, you could give me a brief description of what would be necessary to integrate it?
- What changes to the Ixora dts file would be necessary to get the driver running on both CSI ports of the Ixora board (in a dual camera setup)?
Thank you in advance for your help.
Just to be clear, I’m not asking for you guys to design a new kernel driver for me. Mainly I just would like to know how to add that potential driver to the oe-core LinuxImage3.0 build and I’ll try it myself. Also, just need to know what, if anything, needs to change in the Ixora device tree to enable that driver when I try it.
Hi @nathanluck and Welcome to the Toradex Community!
Regarding you questions:
- Yes, you can integrate the driver in the Yocto build, but first I suggest you try integrate this driver with the sources of the Linux Kernel as explained here. Once this is done, then you need to write a custom recipe to integrate this driver in the kernel.
- Please check the answer in 1.
- Which both CSI Ports are you talking about? Ixora has only one CSI Port.
