I’m trying to write a simple program that uses multiple threads but I’m not having much luck. For now I’m using VS2008 with C++.
I’ve tried the pthread library but I can’t get past the compile errors when trying to build for a Win32 Smart Device Project. All of my library files, dlls, and header files are in the correct folders, but I can’t get past the “LNK2019: unresolved external symbol” error. Pthread works fine if I compile for windows as a Win32 Console Application.
I’d really like to find a simple example that shows how to use threading that will work with my T30.
Any help would be appreciated. Thanks.
