file: Ixora Altium Project (Altium Designer Release 10)
we only have circuit studio
i couldn’t open the PCB file in the circuit studio. schematics and schismatic library are fine.
Siva
Siva
Dear @Tora,
thank you very much for using the Toradex community.
I exported for you the layout file in the “PCB 5.0 Binary File” format. If I am correct, this is the format required by the CS ‘Altium Legacy PCB’ importer.
Please download the file here: https://share.toradex.com/k0kqsfjrt5da094.
Since we don’t use Circuit Studio, we cannot verify if the importing process is successful: please check the design carefully.
I hope this helps, please don’t hesitate to use again the community if needed.
Hi Diego,
Thanks for the info, but the link is not working it came up with #404 error.
HI @Tora
The Link was corrected.
