Hardware: Colibri i.MX 6
BSP: V2.4
I’m trying to add a new touchscreen driver module into my image using a .bbappend, but is not working.
I created a bbappend of the kernel recipe and a file with a line to enable the driver as a module (ft5x06.cfg).
The kernel .bbappend is showed in the bitbake-layers show-appends.
When I rebuild the image (console-trdx-image), only the fusion_F0710A.ko is in the /lib/modules/3.10.17/kernel/drivers/input/touchscreen/ .
What I’m doing wrong?
Thank you!
…/…/…/meta-test/
├── recipes-kernel
│ └── linux
│ ├── files
│ │ ├── defconfig
│ │ ├── ft5x06.cfg
││ └── linux-toradex-fsl_git.bbappend
FILESEXTRAPATHS_prepend := “${THISDIR}/files:”
SRC_URI += "
file://ft5x06.cfg
#SRC_URI += "\
file://defconfig \
KERNEL_MODULE_AUTOLOAD += “ft5x06_ts”
KERNEL_MODULE_PROBECONF += “ft5x06_ts”
module_conf_ft5x06_ts = “screenres=800x480”
cat files/ft5x06.cfg
CONFIG_TOUCHSCREEN_FT5X06=m
