How to enable Splash screen in lvds output mode?
Splash screen in LVDS mode is not yet fully tested.
You can select the ss.out parameter to 2-3 or 4, depending on the channel you want to use (channel 0, 1 or both), but sometimes the device initialization fails.
In Windows registry i switch out parameter to ‘2’ and i my lvds screen works.
However in bootloader mode when i switch this parameter to this value or ‘3’,‘4’ i see nothing at the startup.
BTW, on vga output i see splash screen.
I hope that you will write this feature to the roadmap for win ce imx6.
