Hardware recommendations for AW-CM276NF on custom board
Greetings, i’m working a custom board for use with the Colibri iMX7D. To make wi-fi available through this board the AW-CM276NF will be employed, so, i would like to ask if there are any recommendations such as capacitors and resistors or hardware in general to connect this CI to the board and to the colibri via SDIO.
Thanks in advance.
Hi @rafael_at!
Thanks for contacting us.
We have no particular recommendations besides the ones given by AzureWave in the product datasheet.
You should follow their recommended layout and schematics, adapting them to your carrier board needs.
Moreover, we always recommend checking our Design Guides. We have guides for PCB Layout and Carrier Board Design.
