I connected my camera to X28 MIPI-CSI port, followed this guide, and wanted to see camera preview. Initially in devices I used ‘/dev/video4’ and got an exception:
wayland_1 | ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
wayland_1 | Additional debug info:
wayland_1 | xvimagesink.c(1773): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
wayland_1 | Could not open display (null)
After that I tried all devices returned by “dmesg | grep video”, but every time I got the same exception described above.
I don’t know the cause of this exception and have no idea how to solve it.
Help me please
That’s my Dockerfile for building an image which will use my camera:
FROM torizon/arm64v8-debian-wayland-base-vivante
RUN apt-get -y update && apt-get install -y \
libgstreamer1.0-0 \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
gstreamer1.0-doc \
gstreamer1.0-tools \
gstreamer1.0-x \
gstreamer1.0-alsa \
gstreamer1.0-gl \
gstreamer1.0-gtk3 \
gstreamer1.0-qt5 \
gstreamer1.0-pulseaudio \
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
ENTRYPOINT ["gst-launch-1.0"]
CMD ["-v", "v4l2src", "device=/dev/video10", "!", "capsfilter", "caps=\"video/x-raw, width=640, height=480, framerate=30/1\"", "!", "xvimagesink"]
That’s my docker-compose file:
version: "2.4"
services:
weston:
image: torizon/arm64v8-debian-weston-vivante:latest
network_mode: host
environment:
- ACCEPT_FSL_EULA=1
devices:
- /dev/video10:/dev/video10
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /run/udev
target: /run/udev
- type: bind
source: /dev
target: /dev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- 'c 4:0 rmw'
# ... for tty7
- 'c 4:7 rmw'
# ... for /dev/input devices
- 'c 13:* rmw'
- 'c 199:* rmw'
# ... for /dev/dri devices
- 'c 226:* rmw'
- 'c 81:* rmw'
wayland:
depends_on:
- weston
image: alexey777/camera
devices:
volumes:
- /tmp:/tmp
- /sys:/sys
- /dev:/dev
That’s my output:
Creating torizon_weston_1 ... done
Creating torizon_wayland_1 ... done
Attaching to torizon_weston_1, torizon_wayland_1
weston_1 | NXP EULA has already been accepted.
weston_1 | Switching to VT 7
weston_1 | touch: cannot touch '/tmp/nxp-eula-accepted': Permission denied
weston_1 | Date: 2020-06-04 UTC
weston_1 | [11:29:11.699] weston 5.0.0
weston_1 | https://wayland.freedesktop.org
weston_1 | Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
weston_1 | Build: unknown (not built from git or tarball)
weston_1 | [11:29:11.699] Command line: /usr/bin/weston --current-mode
weston_1 | [11:29:11.699] OS: Linux, 4.14.170-4.0.0-devel+git.fb6b17a22634, #1-TorizonCore SMP PREEMPT Mon May 11 14:38:24 UTC 2020, aarch64
weston_1 | [11:29:11.699] Using config file '/etc/xdg/weston/weston.ini'
weston_1 | [11:29:11.700] Output repaint window is 16 ms maximum.
weston_1 | [11:29:11.700] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/drm-backend.so'
weston_1 | [11:29:11.701] initializing drm backend
weston_1 | [11:29:11.702] using /dev/dri/card0
weston_1 | [11:29:11.702] DRM: supports universal planes
weston_1 | [11:29:11.702] DRM: supports atomic modesetting
weston_1 | [11:29:11.702] DRM: does not support picture aspect ratio
weston_1 | [11:29:11.703] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/gl-renderer.so'
weston_1 | [11:29:11.709] EGL client extensions: EGL_EXT_client_extensions
weston_1 | EGL_EXT_platform_base EGL_KHR_platform_wayland
weston_1 | EGL_EXT_platform_wayland EGL_KHR_platform_gbm
weston_1 | [11:29:11.713] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
weston_1 | [11:29:11.713] EGL_KHR_surfaceless_context available
weston_1 | [11:29:11.718] EGL version: 1.5
weston_1 | [11:29:11.718] EGL vendor: Vivante Corporation
weston_1 | [11:29:11.718] EGL client APIs: OpenGL_ES
weston_1 | [11:29:11.718] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
weston_1 | EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base
weston_1 | EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image
weston_1 | EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
weston_1 | EGL_EXT_image_dma_buf_import
weston_1 | EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface
weston_1 | EGL_KHR_create_context EGL_KHR_surfaceless_context
weston_1 | EGL_EXT_buffer_age EGL_ANDROID_native_fence_sync
weston_1 | EGL_WL_bind_wayland_display
weston_1 | EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update
weston_1 | [11:29:11.718] GL version: OpenGL ES 3.2 V6.2.4.p4.190076
weston_1 | [11:29:11.718] GLSL version: OpenGL ES GLSL ES 3.20
weston_1 | [11:29:11.718] GL vendor: Vivante Corporation
weston_1 | [11:29:11.718] GL renderer: Vivante GC7000XSVX
weston_1 | [11:29:11.718] GL extensions: GL_OES_vertex_type_10_10_10_2
weston_1 | GL_OES_vertex_half_float GL_OES_element_index_uint
weston_1 | GL_OES_mapbuffer GL_OES_vertex_array_object
weston_1 | GL_OES_compressed_ETC1_RGB8_texture
weston_1 | GL_OES_compressed_paletted_texture GL_OES_texture_npot
weston_1 | GL_OES_rgb8_rgba8 GL_OES_depth_texture
weston_1 | GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32
weston_1 | GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap
weston_1 | GL_OES_get_program_binary GL_OES_fragment_precision_high
weston_1 | GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_sync
weston_1 | GL_OES_texture_stencil8 GL_OES_shader_image_atomic
weston_1 | GL_OES_sample_variables GL_OES_sample_shading
weston_1 | GL_OES_texture_storage_multisample_2d_array
weston_1 | GL_OES_shader_multisample_interpolation
weston_1 | GL_OES_required_internalformat GL_OES_surfaceless_context
weston_1 | GL_OES_copy_image GL_OES_draw_buffers_indexed
weston_1 | GL_OES_geometry_shader GL_OES_geometry_point_size
weston_1 | GL_OES_gpu_shader5 GL_OES_shader_io_blocks
weston_1 | GL_OES_texture_border_clamp GL_OES_texture_buffer
weston_1 | GL_OES_tessellation_shader GL_OES_tessellation_point_size
weston_1 | GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex
weston_1 | GL_OES_texture_half_float GL_OES_texture_float
weston_1 | GL_OES_primitive_bounding_box
weston_1 | GL_KHR_texture_compression_astc_ldr
weston_1 | GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness
weston_1 | GL_EXT_texture_type_2_10_10_10_REV
weston_1 | GL_EXT_texture_filter_anisotropic
weston_1 | GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888
weston_1 | GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra
weston_1 | GL_EXT_multi_draw_arrays GL_EXT_frag_depth
weston_1 | GL_EXT_discard_framebuffer GL_EXT_blend_minmax
weston_1 | GL_EXT_multisampled_render_to_texture
weston_1 | GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float
weston_1 | GL_EXT_robustness GL_EXT_texture_sRGB_decode
weston_1 | GL_EXT_draw_buffers_indexed GL_EXT_texture_border_clamp
weston_1 | GL_EXT_texture_buffer GL_EXT_tessellation_shader
weston_1 | GL_EXT_tessellation_point_size GL_EXT_geometry_shader
weston_1 | GL_EXT_geometry_point_size GL_EXT_copy_image
weston_1 | GL_EXT_texture_cube_map_array GL_EXT_gpu_shader5
weston_1 | GL_EXT_shader_io_blocks GL_EXT_shader_implicit_conversions
weston_1 | GL_EXT_multi_draw_indirect GL_EXT_draw_elements_base_vertex
weston_1 | GL_EXT_texture_rg GL_EXT_primitive_bounding_box GL_EXT_sRGB
weston_1 | GL_ANDROID_extension_pack_es31a GL_VIV_direct_texture
weston_1 | [11:29:11.718] GL ES 2 renderer features:
weston_1 | read-back format: BGRA
weston_1 | wl_shm sub-image to texture: yes
weston_1 | EGL Wayland extension: yes
weston_1 | [11:29:11.729] event2 - LITEON Technology USB Multimedia Keyboard: is tagged by udev as: Keyboard
weston_1 | [11:29:11.729] event2 - LITEON Technology USB Multimedia Keyboard: device is a keyboard
weston_1 | [11:29:11.732] event1 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
weston_1 | [11:29:11.732] event1 - Logitech USB Optical Mouse: device is a pointer
weston_1 | [11:29:11.734] event0 - sc-powerkey: is tagged by udev as: Keyboard
weston_1 | [11:29:11.734] event0 - sc-powerkey: device is a keyboard
weston_1 | [11:29:11.747] event3 - colibri-vf50-ts: is tagged by udev as: Touchscreen
weston_1 | [11:29:11.748] event3 - colibri-vf50-ts: device is a touch device
weston_1 | [11:29:11.767] Touchscreen - colibri-vf50-ts - /sys/devices/platform/vf50-touchscreen/input/input3/event3
weston_1 | [11:29:11.768] input device event3 has no enabled output associated (none named), skipping calibration for now.
weston_1 | [11:29:11.793] DRM: head 'HDMI-A-1' found, connector 146 is connected, EDID make 'PHL', model 'PHL 234E5', serial 'UHB142400574'
weston_1 | [11:29:11.793] Registered plugin API 'weston_drm_output_api_v1' of size 24
weston_1 | [11:29:11.803] Chosen EGL config details:
weston_1 | RGBA bits: 8 8 8 0
weston_1 | swap interval range: 1 - 60
weston_1 | [11:29:11.804] No backlight control for output 'HDMI-A-1'
weston_1 | [11:29:11.804] Output HDMI-A-1 (crtc 36) video modes:
weston_1 | 1920x1080@60.0, preferred, current, 148.5 MHz
weston_1 | 1920x1080@59.9, 148.4 MHz
weston_1 | 1920x1080@50.0, 148.5 MHz
weston_1 | 1680x1050@59.9, 119.0 MHz
weston_1 | 1280x1024@75.0, 135.0 MHz
weston_1 | 1280x1024@60.0, 108.0 MHz
weston_1 | 1440x900@75.0, 136.8 MHz
weston_1 | 1440x900@59.9, 88.8 MHz
weston_1 | 1280x720@60.0, 74.2 MHz
weston_1 | 1280x720@59.9, 74.2 MHz
weston_1 | 1280x720@50.0, 74.2 MHz
weston_1 | 1024x768@75.0, 78.8 MHz
weston_1 | 1024x768@60.0, 65.0 MHz
weston_1 | 800x600@75.0, 49.5 MHz
weston_1 | 800x600@60.3, 40.0 MHz
weston_1 | 720x576@50.0, 27.0 MHz
weston_1 | 720x480@60.0, 27.0 MHz
weston_1 | 720x480@59.9, 27.0 MHz
weston_1 | 640x480@75.0, 31.5 MHz
weston_1 | 640x480@72.8, 31.5 MHz
weston_1 | 640x480@66.7, 30.2 MHz
weston_1 | 640x480@60.0, 25.2 MHz
weston_1 | 640x480@59.9, 25.2 MHz
weston_1 | 720x400@70.1, 28.3 MHz
weston_1 | [11:29:11.804] associating input device event2 with output HDMI-A-1 (none by udev)
weston_1 | [11:29:11.804] associating input device event1 with output HDMI-A-1 (none by udev)
weston_1 | [11:29:11.804] associating input device event0 with output HDMI-A-1 (none by udev)
weston_1 | [11:29:11.804] associating input device event3 with output HDMI-A-1 (none by udev)
weston_1 | [11:29:11.806] Output 'HDMI-A-1' enabled with head(s) HDMI-A-1
weston_1 | [11:29:11.806] Compositor capabilities:
weston_1 | arbitrary surface rotation: yes
weston_1 | screen capture uses y-flip: yes
weston_1 | presentation clock: CLOCK_MONOTONIC, id 1
weston_1 | presentation clock resolution: 0.000000001 s
weston_1 | [11:29:11.806] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
weston_1 | [11:29:11.808] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
weston_1 | [11:29:11.816] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/xwayland.so'
weston_1 | [11:29:11.836] Registered plugin API 'weston_xwayland_v1' of size 32
weston_1 | [11:29:11.836] Registered plugin API 'weston_xwayland_surface_v1' of size 16
weston_1 | [11:29:11.836] xserver listening on display :0
weston_1 | [11:29:11.836] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
weston_1 | could not load cursor 'dnd-move'
weston_1 | could not load cursor 'dnd-copy'
weston_1 | could not load cursor 'dnd-none'
wayland_1 | Setting pipeline to PAUSED ...
weston_1 | [11:29:16.328] Spawned Xwayland server, pid 26
weston_1 | glamor: 'wl_drm' not supported
weston_1 | Missing Wayland requirements for glamor GBM backend
weston_1 | Failed to initialize glamor, falling back to sw
weston_1 | [11:29:16.652] xfixes version: 5.0
weston_1 | [11:29:16.712] created wm, root 908
wayland_1 | No protocol specified
wayland_1 | ERROR: Pipeline doesn't want to pause.
wayland_1 | Setting pipeline to NULL ...
wayland_1 | Freeing pipeline ...
torizon_wayland_1 exited with code 255
In the host OS execution of “dmesg | grep video” returns:
[ 0.488475] Linux video capture interface: v2.00
[ 3.520406] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 3.520502] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 3.520603] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 3.520699] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 3.520797] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 3.520894] mx8-img-md: Registered mxc_isi.5.capture as /dev/video5
[ 3.521016] mx8-img-md: Registered mxc_isi.6.capture as /dev/video6
[ 3.521116] mx8-img-md: Registered mxc_isi.7.capture as /dev/video7
[ 3.523763] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video9 (81,19)
[ 3.524688] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video10 (81,20)
In the host OS execution of “dmesg | grep camera” returns:
[ 3.519099] ov5640_probe camera mipi ov5640, is found
[ 3.521421] mxc-md camera: mxc_md_create_links
