hi everone,
i bought ixora carrier board, apalis imx8 module and 10.1 touch display. i connected display on carrier board and run ixora board. But, i cannot see anyting on display. could you please help me about this?
melih
hi everone,
melih
Hi @melih and Welcome to the Toradex Community!
Could you provide the version of the Hardware ( including carrier board) of your module?
Could you install a Bsp 3.0.4 using Toradex Easy Installer on the SoM and check if you see anything on the display?
Thanks and best regards,
hi jaski,
som module: Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06543274
carrier board: ixora v1.1A
display: capacitive touch 10.1 inch
u-boot: U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
kernel: Linux Kernel 4.14.159-2.0.4+gfff496c2a1bd
ok. i will try.
hi jaski,
i tried to install Bsp 3.0.4 image. But i could not be successful. Because Toradex Easy Installer not working, not displaying. The 10.1 inch display and monitor connected to ixora carrier board correctly. unfortunately Toradex easy installer did not display on any device. Could you please help me how can i display toradex easy installer screen?
Hi
Thanks for your Input. Let us know if you have any further questions.
