I’ve been trying to play a video in mp4 format in torizon/arm64v8-debian-kiosk-mode-browser:latest, but the browser can’t play it. In logs there are such errors:
[254:13:0619/134628.182347:ERROR:batching_media_log.cc(26)] MediaEvent: MEDIA_ERROR_LOG_ENTRY {"error":"FFmpegDemuxer: no supported streams"}
[254:1:0619/134628.189686:ERROR:batching_media_log.cc(26)] MediaEvent: PIPELINE_ERROR DEMUXER_ERROR_NO_SUPPORTED_STREAMS
How to make the browser play the video? Or are there other supported browsers where it’s possible?
My docker-compose file
version: "2.4"
services:
weston:
image: torizon/arm64v8-debian-weston-vivante:latest
network_mode: host
environment:
- ACCEPT_FSL_EULA=1
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /run/udev
target: /run/udev
- type: bind
source: /dev
target: /dev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- 'c 4:0 rmw'
# ... for tty7
- 'c 4:7 rmw'
# ... for /dev/input devices
- 'c 13:* rmw'
- 'c 199:* rmw'
# ... for /dev/dri devices
- 'c 226:* rmw'
- 'c 81:* rmw'
browser:
image: torizon/arm64v8-debian-kiosk-mode-browser:latest
security_opt:
- seccomp:unconfined
command: --browser-mode https://www.w3schools.com/html/mov_bbb.mp4
shm_size: 256mb
volumes:
- /tmp:/tmp
- /var/run/dbus:/var/run/dbus
- type: bind
source: /dev/dri
target: /dev/dri
depends_on:
- weston
Console output
Creating torizon_weston_1 ... done
Creating torizon_browser_1 ... done
Attaching to torizon_weston_1, torizon_browser_1
weston_1 | NXP EULA has already been accepted.
weston_1 | Switching to VT 7
weston_1 | touch: cannot touch '/tmp/nxp-eula-accepted': Permission denied
weston_1 | Date: 2020-06-19 UTC
weston_1 | [13:46:22.275] weston 5.0.0
weston_1 | https://wayland.freedesktop.org
weston_1 | Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
weston_1 | Build: unknown (not built from git or tarball)
weston_1 | [13:46:22.275] Command line: /usr/bin/weston --current-mode
weston_1 | [13:46:22.275] OS: Linux, 4.14.170-4.0.0-devel+git.fb6b17a22634, #1-TorizonCore SMP PREEMPT Mon May 11 14:38:24 UTC 2020, aarch64
weston_1 | [13:46:22.276] Using config file '/etc/xdg/weston/weston.ini'
weston_1 | [13:46:22.276] Output repaint window is 16 ms maximum.
weston_1 | [13:46:22.276] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/drm-backend.so'
weston_1 | [13:46:22.278] initializing drm backend
weston_1 | [13:46:22.282] using /dev/dri/card0
weston_1 | [13:46:22.282] DRM: supports universal planes
weston_1 | [13:46:22.282] DRM: supports atomic modesetting
weston_1 | [13:46:22.282] DRM: does not support picture aspect ratio
weston_1 | [13:46:22.283] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/gl-renderer.so'
weston_1 | [13:46:22.292] EGL client extensions: EGL_EXT_client_extensions
weston_1 | EGL_EXT_platform_base EGL_KHR_platform_wayland
weston_1 | EGL_EXT_platform_wayland EGL_KHR_platform_gbm
weston_1 | [13:46:22.297] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
weston_1 | [13:46:22.297] EGL_KHR_surfaceless_context available
weston_1 | [13:46:22.302] EGL version: 1.5
weston_1 | [13:46:22.302] EGL vendor: Vivante Corporation
weston_1 | [13:46:22.302] EGL client APIs: OpenGL_ES
weston_1 | [13:46:22.303] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
weston_1 | EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base
weston_1 | EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image
weston_1 | EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
weston_1 | EGL_EXT_image_dma_buf_import
weston_1 | EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface
weston_1 | EGL_KHR_create_context EGL_KHR_surfaceless_context
weston_1 | EGL_EXT_buffer_age EGL_ANDROID_native_fence_sync
weston_1 | EGL_WL_bind_wayland_display
weston_1 | EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update
weston_1 | [13:46:22.303] GL version: OpenGL ES 3.2 V6.2.4.p4.190076
weston_1 | [13:46:22.303] GLSL version: OpenGL ES GLSL ES 3.20
weston_1 | [13:46:22.303] GL vendor: Vivante Corporation
weston_1 | [13:46:22.303] GL renderer: Vivante GC7000XSVX
weston_1 | [13:46:22.303] GL extensions: GL_OES_vertex_type_10_10_10_2
weston_1 | GL_OES_vertex_half_float GL_OES_element_index_uint
weston_1 | GL_OES_mapbuffer GL_OES_vertex_array_object
weston_1 | GL_OES_compressed_ETC1_RGB8_texture
weston_1 | GL_OES_compressed_paletted_texture GL_OES_texture_npot
weston_1 | GL_OES_rgb8_rgba8 GL_OES_depth_texture
weston_1 | GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32
weston_1 | GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap
weston_1 | GL_OES_get_program_binary GL_OES_fragment_precision_high
weston_1 | GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_sync
weston_1 | GL_OES_texture_stencil8 GL_OES_shader_image_atomic
weston_1 | GL_OES_sample_variables GL_OES_sample_shading
weston_1 | GL_OES_texture_storage_multisample_2d_array
weston_1 | GL_OES_shader_multisample_interpolation
weston_1 | GL_OES_required_internalformat GL_OES_surfaceless_context
weston_1 | GL_OES_copy_image GL_OES_draw_buffers_indexed
weston_1 | GL_OES_geometry_shader GL_OES_geometry_point_size
weston_1 | GL_OES_gpu_shader5 GL_OES_shader_io_blocks
weston_1 | GL_OES_texture_border_clamp GL_OES_texture_buffer
weston_1 | GL_OES_tessellation_shader GL_OES_tessellation_point_size
weston_1 | GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex
weston_1 | GL_OES_texture_half_float GL_OES_texture_float
weston_1 | GL_OES_primitive_bounding_box
weston_1 | GL_KHR_texture_compression_astc_ldr
weston_1 | GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness
weston_1 | GL_EXT_texture_type_2_10_10_10_REV
weston_1 | GL_EXT_texture_filter_anisotropic
weston_1 | GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888
weston_1 | GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra
weston_1 | GL_EXT_multi_draw_arrays GL_EXT_frag_depth
weston_1 | GL_EXT_discard_framebuffer GL_EXT_blend_minmax
weston_1 | GL_EXT_multisampled_render_to_texture
weston_1 | GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float
weston_1 | GL_EXT_robustness GL_EXT_texture_sRGB_decode
weston_1 | GL_EXT_draw_buffers_indexed GL_EXT_texture_border_clamp
weston_1 | GL_EXT_texture_buffer GL_EXT_tessellation_shader
weston_1 | GL_EXT_tessellation_point_size GL_EXT_geometry_shader
weston_1 | GL_EXT_geometry_point_size GL_EXT_copy_image
weston_1 | GL_EXT_texture_cube_map_array GL_EXT_gpu_shader5
weston_1 | GL_EXT_shader_io_blocks GL_EXT_shader_implicit_conversions
weston_1 | GL_EXT_multi_draw_indirect GL_EXT_draw_elements_base_vertex
weston_1 | GL_EXT_texture_rg GL_EXT_primitive_bounding_box GL_EXT_sRGB
weston_1 | GL_ANDROID_extension_pack_es31a GL_VIV_direct_texture
weston_1 | [13:46:22.303] GL ES 2 renderer features:
weston_1 | read-back format: BGRA
weston_1 | wl_shm sub-image to texture: yes
weston_1 | EGL Wayland extension: yes
weston_1 | [13:46:22.313] event2 - LITEON Technology USB Multimedia Keyboard: is tagged by udev as: Keyboard
weston_1 | [13:46:22.313] event2 - LITEON Technology USB Multimedia Keyboard: device is a keyboard
weston_1 | [13:46:22.317] event1 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
weston_1 | [13:46:22.317] event1 - Logitech USB Optical Mouse: device is a pointer
weston_1 | [13:46:22.318] event0 - sc-powerkey: is tagged by udev as: Keyboard
weston_1 | [13:46:22.318] event0 - sc-powerkey: device is a keyboard
weston_1 | [13:46:22.330] event3 - colibri-vf50-ts: is tagged by udev as: Touchscreen
weston_1 | [13:46:22.331] event3 - colibri-vf50-ts: device is a touch device
weston_1 | [13:46:22.345] Touchscreen - colibri-vf50-ts - /sys/devices/platform/vf50-touchscreen/input/input3/event3
weston_1 | [13:46:22.345] input device event3 has no enabled output associated (none named), skipping calibration for now.
weston_1 | [13:46:22.371] DRM: head 'HDMI-A-1' found, connector 146 is connected, EDID make 'PHL', model 'PHL 234E5', serial 'UHB142400574'
weston_1 | [13:46:22.371] Registered plugin API 'weston_drm_output_api_v1' of size 24
weston_1 | [13:46:22.380] Chosen EGL config details:
weston_1 | RGBA bits: 8 8 8 0
weston_1 | swap interval range: 1 - 60
weston_1 | [13:46:22.381] No backlight control for output 'HDMI-A-1'
weston_1 | [13:46:22.381] Output HDMI-A-1 (crtc 36) video modes:
weston_1 | 1920x1080@60.0, preferred, current, 148.5 MHz
weston_1 | 1920x1080@59.9, 148.4 MHz
weston_1 | 1920x1080@50.0, 148.5 MHz
weston_1 | 1680x1050@59.9, 119.0 MHz
weston_1 | 1280x1024@75.0, 135.0 MHz
weston_1 | 1280x1024@60.0, 108.0 MHz
weston_1 | 1440x900@75.0, 136.8 MHz
weston_1 | 1440x900@59.9, 88.8 MHz
weston_1 | 1280x720@60.0, 74.2 MHz
weston_1 | 1280x720@59.9, 74.2 MHz
weston_1 | 1280x720@50.0, 74.2 MHz
weston_1 | 1024x768@75.0, 78.8 MHz
weston_1 | 1024x768@60.0, 65.0 MHz
weston_1 | 800x600@75.0, 49.5 MHz
weston_1 | 800x600@60.3, 40.0 MHz
weston_1 | 720x576@50.0, 27.0 MHz
weston_1 | 720x480@60.0, 27.0 MHz
weston_1 | 720x480@59.9, 27.0 MHz
weston_1 | 640x480@75.0, 31.5 MHz
weston_1 | 640x480@72.8, 31.5 MHz
weston_1 | 640x480@66.7, 30.2 MHz
weston_1 | 640x480@60.0, 25.2 MHz
weston_1 | 640x480@59.9, 25.2 MHz
weston_1 | 720x400@70.1, 28.3 MHz
weston_1 | [13:46:22.381] associating input device event2 with output HDMI-A-1 (none by udev)
weston_1 | [13:46:22.381] associating input device event1 with output HDMI-A-1 (none by udev)
weston_1 | [13:46:22.381] associating input device event0 with output HDMI-A-1 (none by udev)
weston_1 | [13:46:22.381] associating input device event3 with output HDMI-A-1 (none by udev)
weston_1 | [13:46:22.382] Output 'HDMI-A-1' enabled with head(s) HDMI-A-1
weston_1 | [13:46:22.382] Compositor capabilities:
weston_1 | arbitrary surface rotation: yes
weston_1 | screen capture uses y-flip: yes
weston_1 | presentation clock: CLOCK_MONOTONIC, id 1
weston_1 | presentation clock resolution: 0.000000001 s
weston_1 | [13:46:22.382] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
weston_1 | [13:46:22.385] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
weston_1 | [13:46:22.392] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/xwayland.so'
weston_1 | [13:46:22.412] Registered plugin API 'weston_xwayland_v1' of size 32
weston_1 | [13:46:22.412] Registered plugin API 'weston_xwayland_surface_v1' of size 16
weston_1 | [13:46:22.412] xserver listening on display :0
weston_1 | [13:46:22.413] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
weston_1 | could not load cursor 'dnd-move'
weston_1 | could not load cursor 'dnd-copy'
weston_1 | could not load cursor 'dnd-none'
weston_1 | [13:46:25.273] Spawned Xwayland server, pid 26
weston_1 | glamor: 'wl_drm' not supported
weston_1 | Missing Wayland requirements for glamor GBM backend
weston_1 | Failed to initialize glamor, falling back to sw
weston_1 | [13:46:25.570] xfixes version: 5.0
weston_1 | [13:46:25.631] created wm, root 908
browser_1 | [1:34:0619/134626.229604:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [1:219:0619/134626.770164:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
browser_1 | [1:224:0619/134626.859827:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [1:224:0619/134626.860406:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [1:224:0619/134626.860891:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [1:224:0619/134626.861313:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [1:224:0619/134626.861695:ERROR:bus.cc(393)] Failed to connect to the bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
browser_1 | [45:45:0619/134627.221535:ERROR:sandbox_linux.cc(369)] InitializeSandbox() called with multiple threads in process gpu-process.
browser_1 | [254:13:0619/134628.182347:ERROR:batching_media_log.cc(26)] MediaEvent: MEDIA_ERROR_LOG_ENTRY {"error":"FFmpegDemuxer: no supported streams"}
browser_1 | [254:1:0619/134628.189686:ERROR:batching_media_log.cc(26)] MediaEvent: PIPELINE_ERROR DEMUXER_ERROR_NO_SUPPORTED_STREAMS
