I’m trying to boot Apalis iMX6Q SOM, image loading on to eMMC. Booting is getting interrupted post kernel boot. I have attached the boot logs for the analysis. Kindly support on the issue.
Glimpse of the error message.
ALSA device list:
#0: imx6q-apalis-sgtl5000
#1: imx-spdif
#2: imx-hdmi-soc
**EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
EXT4-fs (mmcblk0p2): write access will be enabled during recovery**
usb 2-1.2: new full-speed USB device number 3 using ci_hdrc
ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
usb 2-1.2: Detected FT-X
**EXT4-fs (mmcblk0p2): recovery complete**
usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
**[mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x400e00][1]**
random: crng init done
usb 2-1.1: new high-speed USB device number 4 using ci_hdrc
usb 2-1.1: config 1 has an invalid interface number: 8 but max is 4
usb 2-1.1: config 1 has an invalid interface number: 10 but max is 4
usb 2-1.1: config 1 has no interface number 1
usb 2-1.1: config 1 has no interface number 4
INFO: task swapper/0:1 blocked for more than 10 seconds.
Not tainted 4.9.166-2.8.6+gd899927 #2
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
swapper/0 D 0 1 0 0x00000000
Backtrace:
[<8083677c>] (__schedule) from [<80836cf8>] (schedule+0x44/0xa4)
r10:e26de798 r9:e26de400 r8:8083752c r7:7fffffff r6:00000000 r5:e57aae40
r4:ffffe000
[<80836cb4>] (schedule) from [<80839c74>] (schedule_timeout+0x1cc/0x274)
r5:e57aae40 r4:7fffffff
[<80839aa8>] (schedule_timeout) from [<80836744>] (io_schedule_timeout+0x7c/0xb4)
r8:8083752c r7:7fffffff r6:00000000 r5:e57aae40 r4:e57aa980
[<808366c8>] (io_schedule_timeout) from [<80837544>] (bit_wait_io+0x18/0x64)
r7:80c02b50 r6:e205db04 r5:00000002 r4:00000002
[<8083752c>] (bit_wait_io) from [<80837188>] (__wait_on_bit+0x68/0xc0)
r5:00000002 r4:e205daf8
[<80837120>] (__wait_on_bit) from [<808372dc>] (out_of_line_wait_on_bit+0x74/0x7c)
r9:e26de400 r8:e212a014 r7:00000002 r6:8083752c r5:e002f840 r4:00000002
[<80837268>] (out_of_line_wait_on_bit) from [<8023baac>] (__wait_on_buffer+0x38/0x3c)
r7:e2109000 r6:00000000 r5:e212a000 r4:e002f840
[<8023ba74>] (__wait_on_buffer) from [<802ccb78>] (jbd2_write_superblock+0x148/0x1c4)
[<802cca30>] (jbd2_write_superblock) from [<802ccd14>] (jbd2_mark_journal_empty+0xb8/0xe8)
r7:00028800 r6:e2109000 r5:e212a014 r4:e212a000
[<802ccc5c>] (jbd2_mark_journal_empty) from [<802cd1c8>] (jbd2_journal_flush+0xf8/0x1b0)
r7:e212a07c r6:e212a07c r5:e212a000 r4:00000000
[<802cd0d0>] (jbd2_journal_flush) from [<80297364>] (ext4_mark_recovery_complete.constprop.13+0x44/0x90)
r9:e26de400 r8:e26de000 r7:00000000 r6:00000000 r5:e26de000 r4:e212a000
[<80297320>] (ext4_mark_recovery_complete.constprop.13) from [<8029d10c>] (ext4_fill_super+0x2704/0x3880)
r5:0000001d r4:e26a5380
[<8029aa08>] (ext4_fill_super) from [<8020db44>] (mount_bdev+0x164/0x190)
r10:00008001 r9:00000000 r8:00008001 r7:e00aa26c r6:00000081 r5:e26de000
r4:e00aa200
[<8020d9e0>] (mount_bdev) from [<80295800>] (ext4_mount+0x20/0x28)
r9:00000060 r8:00000000 r7:80c129dc r6:80c129dc r5:e269f340 r4:802957e0
[<802957e0>] (ext4_mount) from [<8020e5a8>] (mount_fs+0x1c/0xb0)
[<8020e58c>] (mount_fs) from [<8022b9ac>] (vfs_kern_mount.part.2+0x50/0xf8)
r6:00008001 r5:e269f340 r4:e263aa00
[<8022b95c>] (vfs_kern_mount.part.2) from [<8022df6c>] (do_mount+0x164/0xc6c)
r9:00000060 r8:e269f300 r7:e269f340 r6:80c129dc r5:00000000 r4:00008001
[<8022de08>] (do_mount) from [<8022edf0>] (SyS_mount+0x5c/0xc8)
r10:80a0a88c r9:80a0a890 r8:00008001 r7:80a0a890 r6:00000000 r5:e269f300
r4:e269f340
[<8022ed94>] (SyS_mount) from [<80b01298>] (mount_block_root+0x11c/0x280)
r8:00008001 r7:80b4785c r6:e6444420 r5:e26a1000 r4:e26a1000
[<80b0117c>] (mount_block_root) from [<80b01610>] (mount_root+0x128/0x130)
r10:80b4783c r9:80b00604 r8:80b47838 r7:80c46680 r6:80c466a4 r5:80c0663c
r4:0b300002
[<80b014e8>] (mount_root) from [<80b0179c>] (prepare_namespace+0x184/0x1cc)
r9:80b00604 r8:80b47838 r7:80c46680 r6:80c46680 r5:80c466a4 r4:80b4785c
[<80b01618>] (prepare_namespace) from [<80b00ef0>] (kernel_init_freeable+0x1f8/0x208)
r6:80c46680 r5:00000009 r4:80ae70d4
[<80b00cf8>] (kernel_init_freeable) from [<80835f6c>] (kernel_init+0x10/0x118)
r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:80835f5c
r4:00000000
[<80835f5c>] (kernel_init) from [<80107c30>] (ret_from_fork+0x14/0x24)
r5:80835f5c r4:00000000
