Bitbake: .tar.bz2 not created
Hello!
I have been following these guides:
Here are the commands I have run:
mkdir ~/bin
export PATH=~/bin:$PATH
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
cd ~/bin
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImage3.0 -m default.xml
repo sync
. export
sudo nano conf/local.conf ← uncommented MACHINE for apalis iMX6
cd ..
mkdir stuff
git clone -b toradex_4.14-2.3.x-imx git://git.toradex.com/linux-toradex.git
cd linux-toradex
sudo patch -p1 < ~/patch/seventhTry.path ← applying my patch, only edits /drivers/i2c/busses/i2c-imx.c and /drivers/i2c/busses/Kconfig
cd ../build
bitbake linux-toradex ← screenshot of build configuration is as followsalt text
When I run ls /deply/images/apalis-imx6, there is not a tar.bz2 file. This is what is inside that directory:alt text
Is there another place I can look for the .tar.bz2 file in order to flash my iMX6? Did I happen to configure it not to make the .tar.bz2 file?
Thanks for helping out!
Hi @samantha!
According to this:
you’re actually using our BSP 3.0. From that version on, we do not support the “legacy” flashing method anymore. Upon building, you’ll see a tarball with “Tezi” on its name (e.g. Apalis-iMX6_Console-Image-Tezi_3.0b4-20200516.tar). You can use that and the Toradex Easy Installer - which comes pre-installed on the module - to flash the image to your board.
Also, when you bitbake linux-toradex you’re only building the Linux kernel itself. This won’t generate the full Toradex Easy Installer image as mentioned above. To build a full image, you must use one of the targets such as console-tdx-image:
$ bitbake console-tdx-image
Thank you so much @gustavo.tx!
@samantha,
You’re welcome! Please let us know in case you have any further questions.
