We are running a UI inside a docker container. One of the requirements is that users can cleanly shut down the device from the UI, however this is not possible from inside a docker container.
I’ve implemented workarounds for this exact problem in the past by having another process running on the host which handles the shut down on behalf of the container, however this involves maintaining applications outside of the docker environment which we would like to avoid. I realise there are also a bunch people on stack overflow with the same question and the answer is usually something similar to the above.
My question is whether you have a recommended way of shutting down SoMs running Torizon? A button on the UI would be good but a hardware button would also work.
This is cause, ideally you’d want a clean and proper shutdown of all systems rather than a forced off scenario. Which is why you need either a proper interface to the host or maybe the container would need root privileges or such, which can also be problematic in practice.
I’ll continue to look and maybe consult the team here a bit if there’s a better solution.
Just thought of this after the fact, but another interesting approach here would be to use localhost and SSH from the container to the host and execute a shutdown command that way. In this way you’d be running the shutdown command on the host directly without need a special host-container interface.
This does however bring up the issue that you’d need SSH in your container as well as credentials to do the SSH.
wait_for_shutdown.service file will be used to control the service
[Unit]
Description=Wait for the signal to shutdown system through a shared file
[Service]
Restart=on-failure
Type=simple
ExecStart=/opt/app-system/wait_for_shutdown.sh
RestartSec=5
[Install]
WantedBy=multi-user.target
wait_for_shutdown.sh file waits for a signal in the shared file
#!/bin/sh
echo "start wait_for_shutdown service"
echo "waiting" > /var/run/shutdown_signal
echo "start wait_for_shutdown service while-do"
while sleep 1; do
signal=$(cat /var/run/shutdown_signal)
if [ "$signal" == "true" ]; then
echo "wait_for_shutdown service - received shutdown"
echo "done" > /var/run/shutdown_signal
shutdown -h now
fi
done
echo "end wait_for_shutdown service while-do"
wait_for_shutdown_service_install.sh file - use this script to install the service
Hello, I was trying to implement the suggested scripts to shutdown a Verdin iMX8M Plus. I installed the wait_for_shutdown_service and was trying to write to the shutdown_signal file and somehow I’ve lost mount and apt commands. When I reboot the container still starts and I can access an exfat flash from the container but I can’t access it when I log in from teraterm and I’m not in the container. I tried to run mount and realized I don’t have mount and then I realized I also don’t have apt. Do you have a suggestion for how to get them back? Do I need to reinstall the OS?
This thread is a bit dated and as such information here might no longer be accurate or applicable anymore. Could you open a new thread with your question/issue and we can try to assist you with hopefully more up-to-date information.
