Sporadic boot on Apalis i.mx8QM / Ixora
I try to put the board into operation and keep running into boot problems that can be broken down as follows:
98% of all boot processes abort when the kernel starts. The following output can be seen on the serial interface:
`U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+gd626574ba1 (Apr 17 2020 - 19:28:04 +0000)
CPU:   Freescale i.MX8QM revB A53 at 1200 MHz at 55C
DRAM:  4 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06548455
 BuildInfo:
  - SCFW b929edfe, SECO-FW 27167ff2, IMX-MKIMAGE d7f9440d, ATF bb209a0
  - U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+gd626574ba1
switch to partitions #0, OK
flash target is MMC:0
Net:   eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
1243 bytes read in 12 ms (100.6 KiB/s)
## Executing script at 86000000
106496 bytes read in 8 ms (12.7 MiB/s)
Loading hdp firmware from 0x0000000084000000 offset 0x0000000000002000
Loading hdp firmware Complete
105024 bytes read in 19 ms (5.3 MiB/s)
23448064 bytes read in 1019 ms (21.9 MiB/s)
## Flattened Device Tree blob at 84000000
   Booting using the fdt blob at 0x84000000
   Loading Device Tree to 00000000fd65b000, end 00000000fd677a3f ... OK
/dma-controller@5a1f0000, 73440
/dma-controller@591F0000, 74320
/dma-controller@599F0000, 75296
Starting kernel ...
It stays there forever…
The boot process rarely but reproducible ends with a kernel panic. Serial output:
> [    8.963945] Internal error:
> undefined instruction: 0 [#1] PREEMPT
> SMP [    8.972461] Modules linked in:
> libcomposite configfs galcore(O) [
> 8.980436] Process systemd (pid: 1, stack limit = 0xffff000008068000) [
> 8.989017] CPU: 3 PID: 1 Comm: systemd Tainted: G           O
> 4.14.170-3.0.4+gbaa6c24240a4 #1 [    8.999989] Hardware name: Toradex Apalis iMX8QM/QP on Apalis Evaluation
> Board (DT) [    9.009788] task:
> ffff800878668000 task.stack:
> ffff000008068000 [    9.017859] PC is
> at rb_prev+0x4/0x58 [    9.023640] LR
> is at __insert_vmap_area+0x70/0xe0 [
> 9.030447] pc : [<ffff000008c2fe4c>] lr : [<ffff0000081dc1e0>] pstate:
> 80000145 [    9.039968] sp :
> ffff00000806b8d0 [    9.045389] x29:
> ffff00000806b8d0 x28: 0000000000000000
> [    9.052791] x27: ffff0000095459f0
> x26: ffff000008004000  [    9.060143]
> x25: 0000000000000000 x24:
> ffffffffffffffff  [    9.067513] x23:
> ffff7dffbfff0000 x22: 0000000000000001
> [    9.074897] x21: ffff000008000000
> x20: ffff800879969798  [    9.082289]
> x19: ffff800879969780 x18:
> 00000000fffffffe  [    9.089691] x17:
> 0000ffffbb5e02c0 x16: ffff00000821cf50
> [    9.097098] x15: 0000000000000001
> x14: ffffffffffffffff  [    9.104475]
> x13: ffff8008f41ab56f x12:
> ffff8008741ab575  [    9.111848] x11:
> 0000000000000000 x10: ffff00000806ba70
> [    9.119204] x9 : 0000000000000000
> x8 : 0000000000000000  [    9.126536]
> x7 : 0000000000000001 x6 :
> ffff00000939a568  [    9.133826] x5 :
> 0000000000003000 x4 : ffff800878e77098
> [    9.141084] x3 : ffff800878d57b99
> x2 : ffff800878e77098  [    9.148337]
> x1 : ffff800878e77098 x0 :
> ffff800879969798  [    9.155559] Call
> trace: [    9.159817] Exception
> stack(0xffff00000806b790 to
> 0xffff00000806b8d0) [    9.168045]
> b780:
> ffff800879969798 ffff800878e77098 [
> 9.177671] b7a0: ffff800878e77098 ffff800878d57b99 ffff800878e77098
> 0000000000003000 [    9.187315] b7c0:
> ffff00000939a568 0000000000000001
> 0000000000000000 0000000000000000 [
> 9.196924] b7e0: ffff00000806ba70 0000000000000000 ffff8008741ab575
> ffff8008f41ab56f [    9.206526] b800:
> ffffffffffffffff 0000000000000001
> ffff00000821cf50 0000ffffbb5e02c0 [
> 9.216125] b820: 00000000fffffffe ffff800879969780 ffff800879969798
> ffff000008000000 [    9.225730] b840:
> 0000000000000001 ffff7dffbfff0000
> ffffffffffffffff 0000000000000000 [
> 9.235329] b860: ffff000008004000 ffff0000095459f0 0000000000000000
> ffff00000806b8d0 [    9.244928] b880:
> ffff0000081dc1e0 ffff00000806b8d0
> ffff000008c2fe4c 0000000080000145 [
> 9.254523] b8a0: ffff00000806b8f0 ffff0000081dc544 0000ffffffffffff
> 0000000000004000 [    9.264062] b8c0:
> ffff00000806b8d0 ffff000008c2fe4c [
> 9.270656] [<ffff000008c2fe4c>] rb_prev+0x4/0x58 [    9.277104]
> [<ffff0000081dc674>]
> alloc_vmap_area+0x194/0x2f0 [
> 9.284496] [<ffff0000081dde54>] __get_vm_area_node+0xa4/0x1b8 [    9.292055] [<ffff0000081dea84>] __vmalloc_node_range+0x64/0x298 [    9.299774] [<ffff0000081df20c>] vzalloc+0x4c/0x88 [    9.306264]
> [<ffff00000864fa70>]
> n_tty_open+0x18/0xb0 [    9.313003]
> [<ffff000008653de4>]
> tty_ldisc_open.isra.3+0x44/0x88 [
> 9.320694] [<ffff000008654560>] tty_ldisc_setup+0x20/0x68 [
> 9.327833] [<ffff00000864e0ec>] tty_init_dev+0xd4/0x1d8 [    9.334779]
> [<ffff00000864e554>]
> tty_open+0x364/0x450 [    9.341414]
> [<ffff000008224474>]
> chrdev_open+0x8c/0x1a0 [    9.348185]
> [<ffff00000821b4ec>]
> do_dentry_open+0x12c/0x340 [
> 9.355273] [<ffff00000821ca84>] vfs_open+0x4c/0x78 [    9.361646]
> [<ffff00000822ed38>]
> path_openat+0x3a0/0x1258 [
> 9.368546] [<ffff000008230c60>] do_filp_open+0x60/0xc0 [    9.375240]
> [<ffff00000821ce94>]
> do_sys_open+0x164/0x1f8 [    9.381988]
> [<ffff00000821cf60>]
> SyS_openat+0x10/0x18 [    9.388475]
> Exception stack(0xffff00000806bec0 to
> 0xffff00000806c000) [    9.396398]
> bec0: ffffffffffffff9c
> 0000aaaaafb9fb80 0000000000080101
> 0000000000000000 [    9.405750] bee0:
> 0000ffffbb5fc000 0000000000000007
> 206465746e756f4d 6761502065677548 [
> 9.415120] bf00: 0000000000000038 0000000000000001 0000fffff99ffa90
> 0000000000000000 [    9.424508] bf20:
> 656c694620736567 2e6d657473795320
> 000000000000001e 0000000000000020 [
> 9.433912] bf40: 0000ffffbb9181d0 0000ffffbb5e02c0 0000ffffbb814c10
> 0000aaaaafc36000 [    9.443331] bf60:
> 0000000000000015 0000000000080101
> 0000aaaaafb9fb80 0000000000000001 [
> 9.452762] bf80: 0000aaaaafbcf178 0000aaaaafbcf178 0000aaaaafba8e88
> 0000000000000010 [    9.462200] bfa0:
> 0000fffff99ffeb0 0000fffff99ffb50
> 0000ffffbb790f50 0000fffff99ffb50 [
> 9.471652] bfc0: 0000ffffbb5e0308 0000000080000000 ffffffffffffff9c
> 0000000000000038 [    9.481127] bfe0:
> 9.490623] [<ffff000008083ac0>] el0_svc_naked+0x34/0x38 [    9.497610]
> Code: 17ffff36 f9000865 17ffff34
> f9400001 (aa0003e2)  [    9.505413]
> ---[ end trace fdb310136cdd9b87 ]--- [    9.511742] note: systemd[1] exited with preempt_count 1 [    9.518781] Kernel
> panic - not syncing: Attempted to kill
> init! exitcode=0x0000000b [
> 9.518781]  [    9.531361] SMP: stopping secondary CPUs [    9.536978]
> Kernel Offset: disabled [    9.542148]
> CPU features: 0x100200d [    9.547299]
> Memory Limit: none [    9.551998] ---[
> end Kernel panic - not syncing:
> Attempted to kill init!
> exitcode=0x0000000b
The small rest of all boot processes start normally and ends up in the usual login prompt.
Is there something i missed? Any help is appreciated
Hi @mfoerd and Welcome to the Toradex Community!
Could you install a nightly Build 4.0.x from the CI Feeds and check if you still see the issue?
Hi jaski.tx,
thanks for the fast reply. I’m not sure what you mean by
…nightly Build 4.0.x from the CI Feeds…
What is that and where can I get it?
mfoerd
Hi mfoerd
You should install this image:
TDX Wayland with XWayland 5.0.0-devel-20200809+build.33
from CI Feeds. CI Feeds can be activated in Toradex Easy Installer. To load and boot the Toradex Easy Installer, please have a look here.
Hi Jaski,
thanks for your help. The image boots now normal, just some USB issue left for the moment.
mfoerd
