I am trying to build yocto image using ubuntu 20.4 on “Colibri iMX8QXP V1.0B” (using Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth and Iris bord 2.0 A).
I followed the guide: Build Apalis iMX8/Colibri iMX8X OpenEmbedded/Yocto Project Bring-up Image.
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping libsdl1.2-dev xterm
$ sudo ln -s /usr/bin/python3 /usr/bin/python"
$ mkdir ~/bin
$ export PATH=~/bin:$PATH
$ curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
$ chmod a+x ~/bin/repo
$ mkdir imx-yocto-bsp
$ cd imx-yocto-bsp
$ repo init -u git://github.com/toradex/imx-manifest.git -b toradex-linux-sumo -m toradex-4.14.78-1.0.0_ga.xml
$ repo sync
$ MACHINE=colibri-imx8qxp DISTRO=fsl-imx-xwayland source fsl-setup-release.sh -b build
$ bitbake -k fsl-image-validation-imx
During build got following errors:
ERROR: bison-native-3.0.4-r0 do_compile: oe_runmake failed
ERROR: bison-native-3.0.4-r0 do_compile: Function failed: do_compile (log file is located at /home/vagrant/imx-yocto-bsp/build/tmp/work/x86_64-linux/bison-native/3.0.4-r0/temp/log.do_compile.1792765)
ERROR: Logfile of failure stored in: /home/vagrant/imx-yocto-bsp/build/tmp/work/x86_64-linux/bison-native/3.0.4-r0/temp/log.do_compile.1792765
ERROR: Task (virtual:native:/home/vagrant/imx-yocto-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb:do_compile) failed with exit code '1'
ERROR: elfutils-native-0.170-r0 do_compile: oe_runmake failed
ERROR: elfutils-native-0.170-r0 do_compile: Function failed: do_compile (log file is located at /home/vagrant/imx-yocto-bsp/build/tmp/work/x86_64-linux/elfutils-native/0.170-r0/temp/log.do_compile.1792816)
ERROR: Logfile of failure stored in: /home/vagrant/imx-yocto-bsp/build/tmp/work/x86_64-linux/elfutils-native/0.170-r0/temp/log.do_compile.1792816
ERROR: Task (virtual:native:/home/vagrant/imx-yocto-bsp/sources/poky/meta/recipes-support/libgpg-error/libgpg-error_1.27.bb:do_compile) failed with exit code '1'
/tmp/deploy/images$ tree
└── colibri-imx8qxp
└── mx8qx-ahab-container.img
1 directory, 1 file
“Uboot.imx” and “*.rootfs.sdcard.bz2” images are missing from colibri-imx8qxp Folder.
