I’m trying to run an app using the Storyboard Suite from Crank software but I’ve run into a problem when trying to open it using Linux and the Colibri iMX6.
The video link below shows how the application is loaded after I try opening a Storyboard Suite app from Crank Software. The initial screen of the app is loaded and then the desktop immediately takes over the display and device input.
Here is the response I received from Crank Software.
So essentially the desktop and SB are fighting for the same framebuffer. You need to slay off the desktop before running SB.
Try running the following …
sudo service lightdm stop
This option doesn’t appear to be available so I’m wondering if you can offer any other suggestions. Is there some way to keep the desktop from conflicting with the app? Thanks.
