How easy is it to read data from emmc using RCM?
Hi. I’m new. I’m looking for an easy way to read data using rcm. my colibri t30 Board has damaged emmc memory and I would like to try reading the saved data using rcm. is there a good way to do this?
HI @Mihail
Could you provide the version of the hardware (including carrier board) and software of your module?
Recovery mode can be used to load U-Boot in Ram and then read the contents of eMMC. For reading the contents you need to stop in U-Boot and you use this method to mount eMMC Flash as a disk.
