I am working on a project to detect object using Yolo Tiny and OpenCV (Tensor Flow Lite is also possible) using USB cameras. I need to process the frame at least 30 fps.
I was thinking to use Colibri IMX8X or Colibri T30.
Which module from Colibri family do you recommend?
