With BSP 2.8 i could do the following to update the device tree on the device
‘pause UBoot’
run setupdate
run prepare_ubi
run update_fdt
This does not seem to work. This is what i get ( Note : I have network connection and SD with easier installer on it)
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from NAND... OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6ULL 512MB Wi-Fi / Bluetooth V1.1A, Serial# 06487969
Net: Could not get PHY for FEC1: addr 2
eth-1: ethernet@020b4000
Colibri iMX6ULL # run setupdate
starting USB...
Bus usb@02184000: USB EHCI 1.00
Bus usb@02184200: USB EHCI 1.00
scanning bus usb@02184000 for devices... 1 USB Device(s) found
scanning bus usb@02184200 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
ethernet@020b4000 Waiting for PHY auto negotiation to complete.... done
Using ethernet@020b4000 device
TFTP from server 192.168.10.1; our IP address is 192.168.10.2
Filename 'colibri-imx6ull/flash_eth.img'.
Load address: 0x82000000
Loading: *
ARP Retry count exceeded; starting again
Colibri iMX6ULL #
