Apalis T30, OpenEmbedded and NTFS Support
I don’t think this is specifically a Toradex-related question but I’m asking here on the off chance that someone has come across this before and could offer a suggestion as to what I can do to resolve the issue.
I have a USB pen drive which is formatted using NTFS (for >4GB file sizes).
I have bit-baked a fresh V2.8b7 angstrom-qt5-x11-image, and included the ntfs-3g driver. I did previously try just enabling the default ntfs driver in the kernel but this had issues of its own (file sync issues between Linux and Windows, etc).
When the USB flash drive is connected to Windows, I can browse the NTFS drive nicely and I can create/edit/remove files/directories as you would typically expect.
However, when I connect the USB pen drive to the Ixora carrier board with an Apalis T30 module running the Angstrom image, weird things happen:
The drive ( /dev/sdb, note the lack of partition) is mounted automatically to /media/sdb however, I cannot browse this mount point - I get an error of "/media/sdb: Not a directory".
lsblk shows:
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda            8:0    0 447.1G  0 disk
└─sda1         8:1    0 447.1G  0 part /media/sda1
sdb            8:16   1   7.5G  0 disk /media/sdb
mmcblk0      179:0    0   7.3G  0 disk
├─mmcblk0p1  179:1    0    16M  0 part /media/mmcblk0p1
└─mmcblk0p2  179:2    0   7.3G  0 part /
mmcblk0boot0 179:8    0     4M  1 disk
mmcblk0boot1 179:16   0     4M  1 disk
mmcblk1      179:24   0  14.6G  0 disk
└─mmcblk1p1  179:25   0  14.6G  0 part /media/mmcblk1p1
Again, note no partition information for /dev/sdb.
fdisk /dev/sdb:
Disk /dev/sdb: 8053 MB, 8053063680 bytes
248 heads, 62 sectors/track, 1022 cylinders
Units = cylinders of 15376 * 512 = 7872512 bytes
   Device Boot      Start         End      Blocks  Id System
/dev/sdb1          124885      243005   908105142  72 Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
     phys=(80, 13, 10) logical=(124884, 90, 21)
Partition 1 has different physical/logical endings:
     phys=(371, 101, 51) logical=(243004, 44, 36)
Partition 1 does not end on cylinder boundary
/dev/sdb2   ?      125913      252971   976826554  6c Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
     phys=(357, 43, 4) logical=(125912, 85, 11)
Partition 2 has different physical/logical endings:
     phys=(367, 32, 52) logical=(252970, 235, 10)
Partition 2 does not end on cylinder boundary
/dev/sdb3   ?           1           1           0   0 Empty
Partition 3 has different physical/logical beginnings (non-Linux?):
     phys=(0, 10, 0) logical=(0, 0, 1)
Partition 3 has different physical/logical endings:
     phys=(0, 0, 0) logical=(279329, 74, 4)
Partition 3 does not end on cylinder boundary
/dev/sdb4            1803        1803         223+  0 Empty
Partition 4 has different physical/logical beginnings (non-Linux?):
     phys=(0, 0, 0) logical=(1802, 235, 1)
Partition 4 has different physical/logical endings:
     phys=(0, 0, 0) logical=(1802, 242, 13)
Partition 4 does not end on cylinder boundary
I can delete all of the partitions using fdisk and then create a new primary partition of type 7 (HPFS/NTFS)
fdisk /dev/sdb
/dev/sdb1               1        1022     7857105   7 HPFS/NTFS
Yet I still, I actually don’t have access to /dev/sdb1 to create a file system there…
lsblk
And its now that I keep going round in circles.
If I now connect the USB pen drive back to Windows, I can access the NTFS partition and read/write files again. When I plug the drive back into the Ixora carrier board, I now get:
lsblk:
sdc            8:32   1   7.5G  0 disk
└─sdc1         8:33   1   7.5G  0 part
So, progress it would seem - nope. If I try and mount the /dev/sdc1 partition:
root@apalis-t30:~# mount -t ntfs-3g /dev/sdc1 /media/usb-drive/
ntfs-3g-mount: mount failed: Device or resource busy
And this is as far as I ever get. I’ve also tried using exFAT but the same issues apply.
Has anyone managed to successfully bring up and mount an NTFS partition and if so, could anyone share their tips and or processes? Thanks
Depending on what exact hardware (module and carrier board) and software versions of things you are talking about I have my serious doubts whether or not any NTFS support is even compiled in resp. much usable. Have you tried regular EXT3/4 or VFAT?
Yeah, I’ve tried ext4 and that works fine but annoyingly I need to install some 3rd party tools in Windows to support it.
I just don’t trust the NTFS stuff at all so I guess I’ll just stick to ext4.
And why not just using good oldé VFAT for USB pendrives like the rest of the world is doing?
Umm, I think VFAT has a max file size of 4GB? We need more than that.
Ok, yeah, that seems though. Maybe just split them files into smaller pieces and spare yourself the hassle.
Ha, I’d love to - unfortunately we have a software contractor who has other ideas about splitting the files… I’ve got ext4 working pretty well with Windows though so maybe that will be the way to go.
Yeah, but most likely not so easy on that ancient Nvidia downstream Linux kernel 3.1.
you can use exFat its FAT32 without the max file size limit. its supported in windows, mac and linux
Good observation, @nkj. But then it comes with the limitation pointed by @marcel.tx.
@kwebster83, are you going to the ext4 solution, then?
Honestly, I’d suggest you to go for NTFS, judging by your requirements.
@andrecurvello.tx I’m going for the ext4 solution - NTFS is very unreliable whereas ext4 seems to work reliably.
That’s fine, @kwebster83 . Thanks for the feedback.
