I’m attempting to build a Torizon Core image using a containerized build as described Here.
This is failing very early in the process, it appears to be an issue with old versions of repo running on unsupported Python2.
As an aside, is the sudo password for pokyuser documented anywhere? Hard to debug inside the container without this!
Downloading manifest from https://github.com/toradex/toradex-torizon-manifest
remote: Enumerating objects: 3, done.
remote: Counting objects: 100% (3/3), done.
remote: Compressing objects: 100% (3/3), done.
remote: Total 2394 (delta 0), reused 3 (delta 0), pack-reused 2391
Receiving objects: 100% (2394/2394), 478.82 KiB | 367.00 KiB/s, done.
Resolving deltas: 100% (1514/1514), done.
fatal: manifest 'default.xml' not available
fatal: manifest default.xml not found
repo: warning: Python 2 is no longer supported; Please upgrade to Python 3.6+.
... A new version of repo (2.8) is available.
... New version is available at: /workdir/torizon/.repo/repo/repo
... The launcher is run from: /usr/bin/repo
!!! The launcher is not writable. Please talk to your sysadmin or distro
!!! to get an update installed.
File "/workdir/torizon/.repo/repo/main.py", line 628, in <module>
_Main(sys.argv[1:])
File "/workdir/torizon/.repo/repo/main.py", line 602, in _Main
result = run()
File "/workdir/torizon/.repo/repo/main.py", line 595, in <lambda>
run = lambda: repo._Run(name, gopts, argv) or 0
File "/workdir/torizon/.repo/repo/main.py", line 239, in _Run
copts, cargs = cmd.OptionParser.parse_args(argv)
File "/workdir/torizon/.repo/repo/command.py", line 71, in OptionParser
self._Options(self._optparse)
File "/workdir/torizon/.repo/repo/subcmds/sync.py", line 202, in _Options
self.jobs = self.manifest.default.sync_j
File "/workdir/torizon/.repo/repo/manifest_xml.py", line 486, in default
self._Load()
File "/workdir/torizon/.repo/repo/manifest_xml.py", line 555, in _Load
self.manifestProject.worktree))
File "/workdir/torizon/.repo/repo/manifest_xml.py", line 594, in _ParseManifestXml
root = xml.dom.minidom.parse(path)
File "/usr/lib/python2.7/xml/dom/minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "/usr/lib/python2.7/xml/dom/expatbuilder.py", line 922, in parse
fp = open(file, 'rb')
IOError: [Errno 2] No such file or directory: '/workdir/torizon/.repo/manifest.xml'
