Does meta-agl layer is supported in Toradex BSP 5.0 with Apalis IMX6. Will there be any build issue?
I want to know whether meta-agl layer is supported for Toradex BSP 5.0 with Apalis IMX6. If it is not then can you suggest us which platform to choose for AGL(Automotive Grade Linux).
Hi Nitish,
As discussed in the below post Toradex does not maintain meta-agl layer.
https://www.toradex.com/community/questions/55041/can-we-implement-aglautomotive-grade-linux-on-apal.html?childToView=55114#answer-55114
Apart from this, from NXP they have some documentation available which you might like to try.
https://source.codeaurora.org/external/imx/meta-nxp-agl/
Ritesh Kumar
Thank you @ritesh.tx
You are welcome.
