In my application the touch is not necessary so I can to use it and the touch is disabled by default.
I think to disable the PWN5 in order to use this PIN and I can add it on other functionality.
Could you suggest where could I insert this PIN for my purpose?
Could you tell my the right the bitwise definition for the last cell of the definition in order to use the PIN how PULL UP resistor of 22KOhm, I understood to change the bit 15-14 with 11, but the entire value is not clear for me.
I don’t need to change anythink on the file imx6ul-pinfunc.h
It depends what exactly do you want to do? How do you measure the Motorspeed?
You just need to change the values in binary to hex format? What exactly you did not understand?
You never change the values in imx6ul-pinfunc.h unless there is a bug.
