I want to rebuild the kernel / console-tdx-image using my own device tree instead of the imx6ull-colibri-eval-v3.dtsi
I have changed the makefile in the dts folder to build my dtsi file, BUT where do i need to change so that my dtsi gets placed into the package for firmware upgrading ?
You need to change the file name in the file image.json in the Toradex Easy Installer image of Bsp 3.x for Colibri iMX6ULL for the corresponding Products Ids. The Product Ids can be found here.
And i see where i can replace the ‘eval-v3’ with my board name
What i wanted to know is, where (what files) do i need to change so that during the build (bitbake console-tdx-image) it builds MY dtb file instead of the eval-v3 and other unused dtb files
