Well I guess this is what I get for spitting out a patch without testing it.
Can you confirm that you have no issues with USB when using a vanilla unmodified device tree?
Furthermore I recall you had several changes in addition to i2c like CAN changes for example. Can you enable the changes piece by piece and confirm that it’s specifically the i2c4 changes that cause the USB issues and not some other change?
In the meantime I’ll try to find some USB devices to test with on my setup with the patch I gave you previously. I might also need to check with the team internally to see if they know whether one of the changes in the patch could have caused USB issues.
I just find it strange that the i2c4 changes could have caused issues with USB.
Just as an update from my side. I did some small testing with the patch I gave you that just had the i2c changes. I didn’t experience any of the USB issues you were describing.
