I am trying the example UART project at
All is good. The serial port only has a write method that takes string parameter, I’d like to send a byte (0-255) value. My question is, how do I convert values above 128 to string? Is there other method to send raw data (0-255) using serialport?
You find all member functions of the SerialPort class on MSDN. There is a function called Write that does the what you want.
public void Write( byte[] buffer, int offset, int count )
The reference can be found here.
Thanks, exactly what I need.
