iMX7D 5.4.x kernel. Launching M4 FW using remoteproc
My M4 code works well launching it from bootloader using bootaux command. Now I have to launch it from Linux using remoteproc. Device tree for iMX7D doesn’t include any hints for remoteproc. I deduced something like this from other derivatives and kernel Documentation, but there are issues with it:
	reserved-memory {
		#address-cells = <1>;
		#size-cells = <1>;
		ranges;
		vdev0vring0: vdev0vring0@8ffe0000 {
                        compatible = "shared-dma-pool";
			reg = <0x8ffe0000 0x8000>;
			no-map;
		vdev0vring1: vdev0vring1@8ffe8000 {
			reg = <0x8ffe8000 0x8000>;
			no-map;
	imx7d-cm4 {
		compatible = "fsl,imx7d-cm4";
//		ipc-only;
//		rsc-da=<0x1fff8000>;
		mbox-names = "tx", "rx", "rxdb", "txdb";
		syscon = <&src>;
		mboxes = <&mu 0 1
			  &mu 1 1
			  &mu 3 1
			  &mu 2 1>;
		memory-region = <&vdev0vring0>, <&vdev0vring1>;
Why remoteproc forces to define all four mailboxes rx, tx, rxdb and txdb? I need none of them for remoteproc nees, just for rpmsg needs. Remoteproc just has to launch M4 FW. But no MB’s in remoteproc - no remoteproc at all. Nonsense!
Vdevrings defined above don’t match iMX7D FreeRTOS. That was just my attempt to make imx_rpmsg_tty working when I launch M4 FW from remoteproc. Nothing helps. I even tried to change remotproc MU channels, no difference. Has it something to do with “syscon”, missing resources sharing (MU) between remoteproc and imx_rpmsg?
This launches M4 FW, I see LEDs blinking and periodic output on serial console, but /dev/ttyRPMSG0 is missing:
echo -n fwname > /sys/class/remoteproc/remoteproc0/firmware
echo -n start > /sys/class/remoteproc/remoteproc0/state
What exact software versions of things are you talking about (e.g. exact manifest git hashes)? What exact image flavour are you talking about (e.g. downstream vs. upstream/mainline, X11 vs. Xwayland, minimal vs. multimedia)? Attaching the full debug console output of the entire boot process as a textual file may help as well. Thanks!
Greetings @Edward!
I have found some insights about this here and here. I also know of imx-m4fwloader which can be used to load a firmware to the M4 via userspace.
Hi @gustavo.tx ,
Thank you very much for help. Actually booting M4 using bootaux and then M4 code is recognized by imx_rpmsg + imx_rpmsg_tty. As well I’m able to boot M4 using remoteproc, but then RPMSG doesn’t work.
I’m going to try imx-m4fwloader, but it accepts only bin file, and bin file created from elf is about 0.5GB in size. I’ll try figuring what should be rejected from elf to make small bin.
Update: For m4fwloader had to fix *.ld and *.S files, now it boots and results are the same. Bootaux: LEDs blonking, RPMSG working. Remoteproc/m4fwloader: LEDs blonking, RPMSG dead. The same booting to TCM/OCRAM.
Edward
@Edward,
Can you please provide a full dmesg log and your kernel config (zcat /proc/config.gz)?
Hi @gustavo.tx,
sorry for “answering” again again instead of adding comment. It’s bit not intuitive and I failed again.
Since no “openamp” in dmesg, RPMSG device interface doesn’t work as well, though works well when M4 is booted from u-boot.
If you wish to check with M4 part then it is examples/imx7_colibri_m4/demo_apps/rpmsg/str_echo_bm with few mods.
Since m4fwloader doesn’t support *.elf or multiple sections, I had to use different ld and startup files, else arm-none-eabi-objdump -O binary would produce enormously big file and m4fwloader would still not initialize data area. Please see attached *.S and *.ld along with compiled binaries. TCM, so start it with ./m4fwloader rpmsg_str_echo_bm.bin 0x7f8000 and observe some M4 output on debug console.
Edward
CMakeLists.diff MCIMX7D_M4_tcm_my.ld rpmsg_str_echo_bm.bin rpmsg_str_echo_bm.elf startup_MCIMX7D_M4.S
@gustavo.tx,
Just restored to default kernel config. The same. M4 working properly after launching with ./m4fwloader fw-tcm.bin 0x7F8000, but no /dev/ttyRPMSG0 or virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x0 in dmesg. I even tried kicking MU with m4fwloader. Kicks are recognised by M4, but no openmap in dmesg.
dmesg config
kernel cloned from here . Xwayland, minimal.
Initial device tree doesn’t provide working remoteproc settings for imx7d, I mean compatible “fsl,imx7d-cm4”, so that it would work with both imx_rproc and imx_rpmsg drivers. Whatever I do, in case M4 is started from remoteproc/imx_rproc, imx_rpmsg doesn’t see M4 talking. I mean missing virtio_rpmsg_bus strings like this
[ 1855.725824] virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x0
[ 1855.734294] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1855.741298] imx rpmsg driver is registered.
I see only this:
@Edward,
I’m gonna try to reproduce this and let you know.
@Edward,
Can you please share your changes to the device tree? I tried something based on your first post but couldn’t make it work as an overlay.
Hi @gustavo.tx,
Actually with m4fwloader we can eliminate remoteproc from puzzle and concentrate on why it matters for rpmsg whether M4 or Linux boots first.
I already modified tree and don’t have original one. Here’s what I have now, nombox = "true"; is from my attempt to cut all MU stuff from remoteproc driver. I thought it could matter somehow, but m4fwloader just confirms that something is not right either in RPMSG.
/dts-v1/;
#include "imx7d-colibri.dtsi"
#include "imx7-colibri-eval-v3.dtsi"
	model = "Toradex Colibri iMX7D on Colibri Evaluation Board V3";
	compatible = "toradex,colibri-imx7d-eval-v3",
		     "toradex,colibri-imx7d",
		     "fsl,imx7d";
/*	memory@80000000 {
		device_type = "memory";
		reg = <0x80000000 0x0fff0000>,
		      <0x90000000 0x10000000>;
	reserved-memory {
		#size-cells = <1>;
		ranges;
		vrings0@0x8fff0000 {
			reg = <0x8fff0000 0x10000>;
			no-map;
		cm4sramcode: cm4sramcode@0x900000 {
			reg = <0x00900000 0x40000>;
			no-map;
		cm4tcmcode: cm4tcmcode@0x7f8000 {
			reg = <0x007f8000 0x8000>;
			no-map;
		_vdev0vring0: _vdev0vring0@8fff0000 {
			reg = <0x8fff0000 0x8000>;
			no-map;
		_vdev0vring1: _vdev0vring1@8fff8000 {
			reg = <0x8fff8000 0x8000>;
			no-map;
	imx7d-cm4 {
		compatible = "fsl,imx7d-cm4", "syscon";
//		ipc-only;
//		rsc-da=<0x8fff0000>;
		nombox = "true";
		syscon = <&src>;
		mboxes = <&mu 0 1
			  &mu 1 1
			  &mu 3 1
			  &mu 2 1>;
//		memory-region = <&vdev0vring0>, <&vdev0vring1>;
		memory-region = <&cm4sramcode>, <&cm4tcmcode>;
@Edward,
This really looks like something going on with the RPMsg implementation. Did you check if the kernel modules loaded correctly?
Would you be able to inquire NXP in their community regarding this, since their implementation is not upstream? Meanwhile I’m checking internally if we’re able to further investigate this. What exactly is your use case? Do you have an application that should launch the firmware using remoteproc? Is launching the firmware from Linux an absolute requirement?
Hi @gustavo.tx,
Yes, modules load fine.
  • Would you be able to inquire NXP in their community regarding this, since their implementation is not upstream?
To request them I need to use their kernel. Do they have one that could run on Colibri? Any directions I could try their kernel? Actually I’m not familiar with what is up and down-stream.
  • What exactly is your use case? Do you have an application that should launch the firmware using remoteproc? Is launching the firmware from Linux an absolute requirement?
M4 is must have due to real time requirements not achievable with Linux only. Not an absolute requirement, but I already upgraded all required VF61 drivers for 5.4 kernel, including rpmsg and remoteproc. remoteproc + rpmsg is working. It would be nice if the same M4 approach could work as well on iMX7D.
  1. Unlike remoteproc for VF61, remoteproc for iMX7D allows M4 code reload, which would greatly speed up M4 debugging!
  2. Services or whatever it is called feature sounds interesting. If it worked, I’d try to use different “rpc” calls
  3. Bootauxing M4 code from u-boot makes u-boot and its environment variables more critical part, which I would like to avoid.
  4. Upgrading application code could be limited to rootfs only…
Since you mention upstream, I diffed toradex_5.4.y/drivers/rpmsg with toradex_5.4-2.3.x-imx/drivers/rpmsg. virtio_rpmsg_bus.c is different even when CONFIG_RPMSG_VIRTIO_CHAR is not defined… I think I should try that driver, unfortunately no time for it by now.
Edward
@Edward,
The downstream kernel we’re using is actually based on the NXP release. Just make sure you’re using the toradex_5.4-2.3.x-imx branch. The toradex_5.4.y branch contains our mainline-based kernel, as you noticed.
Hi @gustavo.tx
Thanks for your reply. I tried those versions, no go. For some reason rpmsg doesn’t start if M4 is started from Linux. I’ll look for differences between VF61 and iMX7D code when time permits. Of course iMX7D carrier board with JTAG could help, perhaps we will buy one.
@Edward,
Let me know of any developments on your side. I’ll also make sure to update this topic and the developer documentation in case of any new findings.
Hi @gustavo.tx,
Thank you. No, I had to switch to different taks, u-boot currently launches M4. If nothing breaks plans, I’m going to play with it soon.
Looking for something else I found This and This . I was trying to modularize rpmsg and reload modules, perhaps I modularized some different part of it, I should check. Aster and JTAG debugger are ready, so I hope it will be solved.
Hi @gustavo.tx,
I found something weird. 4.14 kernel or 5.x - the same issue. Modifying 4.14 Kconfig files I made imx_rpmsg driver loadable, put printk’s to trace MU driver and imx_rpmsg calls. Issue is somewhat fuzzy behaving device tree. I don’t know, but if cat /sys/firmware/devicetree/../rpmsg/status gives disabled, then even don’t try launching M4 from Linux, RPMSG won’t work. If status is OK, then starting M4 by m4fwloader, JTAG debugger, perhaps remoteproc as well should make RPMSG working, no matter is imx_rpmsg loaded before launching M4 or after.
The problem is something flips rpmsg DT status in /sys/firmware from okay to disabled.
Without doing any changes to DT, using the same *.dtb file, one time /sys status matches DT and is okay, and another time it doesn’t match DT and is disabled:
  1. Loading M4 FW and then issuing bootaux - makes imx_rpmsg /sys status okay.
  2. Not loading M4 FW after reset and just issuing to uninitialized memory bootuax 80800000 - makes imx_rpmsg /sys status okay again :-).
  3. Not touching bootaux, using JTAG debugger without any cool Linux kernel support or something, setting HW breakpoint at /init/main.c start_kernel() routine, reaching that breakpoint (so it stops for a while), then continuing executing … makes imx_rpmsg /sys status okay again. :slight_smile:
  4. Not using bootaux or JTAG renders /sys/firmware/devicetree/../rpmsg/status disabled. Since disabled, driver isn’t probed, which gives no chance to get RPMSG working launching M4 from Linux.
I’m picking main hair why it is so. Made many different searches though kernel sources to find what could render imx_rpmsg status disabled, no results yet.
Any advice how to figure why status could flip from okay in dtb to disabled in /sys? p4 above suggests something like missing cache flush, missing sync barrier, broken RAM, etc.
Loading dtb file in U-Boot and inspecting DT settings using fdt list and fdt print confirms okay. But Linux sometimes doesn’t agree with this.
Edward
Hi @gustavo.tx,
Well, I have workaround for oddities mentioned in my previous message. In short, for some odd reasons Linux may flip status of first rpmsg device from okay to disabled. My workaround is to disable first rpmsg instance and create new one. Renaming first instance didn’t work, mystery. Let me give you some details, which may help understanding better or reproducing.
  1. Teziying latest stable: TDX Wayland with XWayland 5.1.0+build.4 (dunfell) colibri-imx7 ttymxc0 Colibri-iMX7_Reference-Minimal-Image
  2. Not touching everything and not bootaux’ing M4 FW, original imx7d-colibri-eval-v3.dtb
    [upload|HCD2O/e2RUj0udSJslkLetK+B90=]
  3. Check what’s inside dtb:
    [upload|9bwYANbs7HrkTCByAz0Diw1qimk=]
  4. Disabling first rpmsg, adding second rpmsg, reserving memory for vring:
    diff --git a/imx7d-colibri-eval-v3.dts~ b/imx7d-colibri-eval-v3.dts
    index 3d2b48e..9af58c9 100644
    --- a/imx7d-colibri-eval-v3.dts~
    +++ b/imx7d-colibri-eval-v3.dts
    @@ -49,8 +49,48 @@
                         "fsl,imx7d";
    +       reserved-memory {
    +               #address-cells = <1>;
    +               #size-cells = <1>;
    +               ranges;
    +               rpmsg-vrings@0x8fff0000 {
    +                       compatible = "shared-dma-pool";
    +                       reg = <0x8fff0000 0x10000>;
    +                       no-map;
    +       soc {
    +               rpmsg1 {
    +                       vdev-nums = <1>;
    +                       status = "okay";
    +                       compatible = "fsl,imx7d-rpmsg";
    +                       /* up to now, the following channels are used in imx rpmsg
    +                       * - tx1/rx1: messages channel.
    +                       * - general interrupt1: remote proc finish re-init rpmsg stack
    +                       *   when A core is partition reset.
    +                       mbox-names = "tx", "rx", "rxdb";
    +                       mboxes = <&mu 0 1
    +                               &mu 1 1
    +                               &mu 3 1>;
    +/* defined in imx7s.dtsi, disabled. Reenabled and specified VRING address
    +   in imx7-colibri.dtsi.
    +    Disabled it and redefine new instance
    +&rpmsg {
    +       status = "disabled";
     &usbotg2 {
            vbus-supply = <&reg_usbh_vbus>;
  1. Check dtb:
    [upload|bCWroN70x4aYXd2TRSRjKjgJ8JI=]
  2. Result, 2nd rpmsg instance visible to Linux:
    [upload|kBvcBdbKcEI3719ro6Ybztm+x0Q=]
Since status is OK, imx_rpmsg driver can be successfully probed. I was able to launch M4 from Linux and got RPMSG working. Remoteproc should work as well, will check later
Hi @gustavo.tx,
OK, it turns out that guilty for these issues is U-Boot. It checks if M4 was started or just attempted to start and disables in DT “fsl,imx7d-rpmsg”.
Here’s excerpt from u-boot-2020.07/u-boot-toradex/board/toradex/colibri_imx7/colibri_imx7.c:
#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP)
int ft_board_setup(void *blob, bd_t *bd)
#if defined(CONFIG_IMX_BOOTAUX) && defined(CONFIG_ARCH_FIXUP_FDT_MEMORY)
	int up;
	up = arch_auxiliary_core_check_up(0);
	if (up) {
		int ret;
		int areas = 1;
		u64 start[2], size[2];
		 * Reserve 1MB of memory for M4 (1MiB is also the minimum
		 * alignment for Linux due to MMU section size restrictions).
		start[0] = gd->bd->bi_dram[0].start;
		size[0] = SZ_256M - SZ_1M;
		/* If needed, create a second entry for memory beyond 256M */
		if (gd->bd->bi_dram[0].size > SZ_256M) {
			start[1] = gd->bd->bi_dram[0].start + SZ_256M;
			size[1] = gd->bd->bi_dram[0].size - SZ_256M;
			areas = 2;
		ret = fdt_set_usable_memory(blob, start, size, areas);
		if (ret) {
			eprintf("Cannot set usable memory\n");
			return ret;
	} else {
		int off;
		off = fdt_node_offset_by_compatible(blob, -1,
						    "fsl,imx7d-rpmsg");
		if (off > 0)
			fdt_status_disabled(blob, off);
Please remove removal of imx7d-rpmsg device from DT!
Edward
