We are working on a project in which we need to port Fedora-IoT rootfs on iMx8 (NXP) board. Below is the approach we have taken and queries we have.
We have taken the Linux kernel from NXP version - Kernel 5.4.47-2.2.0+g88d90ad100ab on an aarch64 and u-boot from also NXP.
We have extracted the rootFS from the binary on the below link.
SD card structure we have made for the imx8 board - Fedora-IoT rootfs:
u-boot will be copied on SD card using dd command
boot partition - dtb and kernel images
root partition - Fedora IoT rootfs
After successful boot up of the board we got below logs:
Fedora 33.20201215.0 (IoT Edition)
Kernel 5.4.47-2.2.0+g88d90ad100ab on an aarch64 (ttymxc0)
Browse to https://provision.fedoraproject.org to claim this device (device ID not yet known) and configure SSH keys deployed
localhost login: root
Password:
Below command is not working for us and it halts all the installation process, which stops other main activities.
[root@localhost ~]# rpm-ostree status
error: loading sysroot: Unexpected state: /run/ostree-booted found and in / sysroot, but bootloader entry not found
Could you please help us over here?
Parth Y Shah
