Dear. Toradex Engineers.
Hi I am Jin and beginer in embedded linux
I am trying to use 3.5" LCD panel with Colibri iMX6ULL.
I could display qt demo of Colibri iMX6ULL on the LCD.
I did setting about LCD resolution by using Device Tree Customization(code is below)
and I want to rotate the display at 180degree
How to that? more the using Device Tree Customization? or Do I have to edit uEnv.txt ?
help me. thank you
&lcdif {
display = <&display0>;
display0:lcd-display {
bits-per-pixel = <16>;
bus-width = <18>;
display-timings {
native-mode = <&timing_qvga>;
/* Standard QVGA timing */
timing_qvga: 320x240 {
clock-frequency = <6500000>;
hactive = <320>;
vactive = <240>;
hback-porch = <68>;
hfront-porch = <19>;
vback-porch = <18>;
vfront-porch = <3>;
hsync-len = <1>;
vsync-len = <1>;
de-active = <0>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
