Q: Can you please post more details on software version you are using?
Reply: NetworkManager version – > 1.22.10,
ModemManager version – > 1.12.12,
Kernel version → 5.4.77
Q:Also which modem are you trying to connect and interface you are using?
Reply: Quectel EC25-E
What are the sequence of steps you are following ?
Reply:
1.Identifying the wwan interface is managed or not.
root@apalis-imx6:~# nmcli d
DEVICE TYPE STATE CONNECTION
eth1 ethernet connected Wired connection 1
eth2 ethernet unavailable –
can0 can unmanaged –
can1 can unmanaged –
eth0 ethernet unmanaged –
usb0 ethernet unmanaged –
lo loopback unmanaged –
wwan0 wwan unmanaged –
root@apalis-imx6:~# nmcli -p
eth1: connected to Wired connection 1
"Microchip LAN7500"
ethernet (smsc75xx), 00:1E:C0:E0:89:FD, hw, mtu 1500
ip4 default
inet4 192.168.126.223/22
route4 0.0.0.0/0
route4 192.168.124.0/22
inet6 fe80::7473:5bc3:5e0c:1bfb/64
route6 fe80::/64
route6 ff00::/8
eth2: unavailable
"Microchip SMSC9512/9514"
ethernet (smsc95xx), 00:1E:C0:E1:09:7D, hw, mtu 1500
wwan0: unavailable
"Quectel EC25"
wwan (qmi_wwan), CA:94:10:9D:E4:CA, plugin missing, hw, mtu 1500
2.As you can see wwan0 is showing as unmanaged and plug-in is missing,so i have run a
command("nmcli dev set wwan0 managed yes") to set as managed one.
3.Now wwan interface is showing as unavailable.
eth2 ethernet unavailable --
wwan0 wwan unavailable --
can0 can unmanaged --
can1 can unmanaged --
eth0 ethernet unmanaged --
usb0 ethernet unmanaged --
lo loopback unmanaged --
root@apalis-imx6:~# nmcli con add type gsm con-name Modem ifname wwan0 apn airtelgprs.com
Warning: There is another connection with the name 'Modem'. Reference the connection by its uuid 'a6f15d26-06c3-4409-ac56-012c035f193f'
Connection 'Modem' (a6f15d26-06c3-4409-ac56-012c035f193f) successfully added.
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~#
root@apalis-imx6:~# cat /etc/NetworkManager/system-connections/
Modem-a6f15d26-06c3-4409-ac56-012c035f193f.nmconnection cell1
Modem.nmconnection
root@apalis-imx6:~# cat /etc/NetworkManager/system-connections/Modem-a6f15d26-06c3-4409-ac56-012c035f193f.nmconnection
[connection]
id=Modem
uuid=a6f15d26-06c3-4409-ac56-012c035f193f
type=gsm
interface-name=wwan0
permissions=
[gsm]
apn=airtelgprs.com
[ipv4]
dns-search=
method=auto
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
[proxy]
NAME UUID TYPE DEVICE
Wired connection 1 977d1334-9847-382d-b222-97576edbe592 ethernet eth1
Modem 1862ec1c-3987-4bee-ab37-a15a3caea24a gsm --
Modem a6f15d26-06c3-4409-ac56-012c035f193f gsm --
Wired connection 2 1bcc27b2-2e81-3e7f-822c-be806b287235 ethernet --
Q:Please also share the output of below commands
mmcli -m 0
nmcli c
Reply:
root@apalis-imx6:~# mmcli -m 0
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: ba3997d4bf1e6db67a476314710c02cfb3f58eb7
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EC25EFAR06A08M4G
| carrier config: default
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 860548045586564
System | device: /sys/devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.1/1-1.1.2
| drivers: option1, qmi_wwan
| plugin: Quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at), wwan0 (net),
| ttyUSB1 (gps), ttyUSB3 (at)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: gsm
| signal quality: 100% (recent)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-5, eutran-7, eutran-8, eutran-20, eutran-38, eutran-40,
| eutran-41
| current: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-41
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 860548045586564
| operator id: 40449
| operator name: airtel
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
