I am using an Apalis iMX6Q IT 2GB module on a custom carrier board and need to utilize all 5 UART’s on the module. The OS is a custom build based on BSP 5.1.0-devel+git.a2f08dfd79ae. UART’s 1-4 seem to be functioning normally and show in /dev as “apalis-uart1 … 4”. However I cannot seem to get UART 5 to show. I do however have “ttymxc0 … 4” which I believe is the UARTs. My device tree files are as follows
- imx6q-apalis-acu3.dts
- imx6qdl-apalis.dtsi
- imx6qdl-apalis-acu3.dtsi
I have made the following to these files
imx6qdl-apalis.dtsi - Added too
&uart3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart3_dte>;
fsl,dte-mode;
status = "disabled";
&iomuxc {
pinctrl_uart3_dce: uart3dcegrp {
fsl,pins = <
MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b1
MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b1
/* DTE mode */
pinctrl_uart3_dte: uart3dtegrp {
fsl,pins = <
MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x1b0b1
MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x1b0b1
imx6qdl-apalis-acu3.dtsi - Added too
&uart3 {
What am I missing here? Is it possible that since this 5th UART is not technically apart of the apalis standard UART’s that all that will show is the appropriate ttymxc and /dev will never have an apalis-uart5? I have attached the full device tree files here. Any help on this would be greatly appreciated.
