Hey,
I am trying to make the GPIO demo working while Linux is running. I found out, that:
“The interrupt part of the demo only works as long as Linux is not running. The reason for that is that Linux uses the same GPIO bank too, and reconfigures interrupts. The easiest way to use GPIO in interrupt mode on FreeRTOS while using Linux is to assign a complete GPIO bank to FreeRTOS and disabling the GPIO bank in Linux’ device tree.”
After a little struggle I finally can compile device trees. Now I want to ask how exactly can I disable the GPIO4 bank?
I tried:
**gpio4: gpio@30230000 {status = "disabled";}**
and
**&gpio4{
both give me an error like:
~/linux-toradex$ make imx7d-colibri-emmc-eval-v3.dtb ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
CHK scripts/mod/devicetable-offsets.h
DTC arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dtb
Error: arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dts:25.8-21 syntax error
FATAL ERROR: Unable to parse input tree
make[1]: *** [scripts/Makefile.lib:313: arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dtb] Error 1
make: *** [arch/arm/Makefile:336: imx7d-colibri-emmc-eval-v3.dtb] Error 2
I hope you can help me
Thanks in advance
