How can I remove the graphical UI after the boot on Linux version 3.0? The one that is basically a terminal with mouse input.
Hi @Ilan_Figueiredo ,
Are you using yocto? If yes, did you use the console-tdx-image
as a reference for your image recipe?
Daniel Morais
Yes. I believe it is the xinit. I am unsure in which layer it is being added.
To be more precise, where in which layer is the xserver-nodm.service added to the systemd in the BitBaking process?
Normally there is a variable called IMAGE_FEATURES
where there is a IF that checks the DISTRO_FEATURES
variable, see below the example for the lxde-image.bb
IMAGE_FEATURES += " \
${@bb.utils.contains('DISTRO_FEATURES', 'wayland', '', \
bb.utils.contains('DISTRO_FEATURES', 'x11', 'x11', \
'', d), d)} \
Just baked with the changes and it worked.
Perfect. Thanks for your feedback.
