Hi there,
after successful start with Easy Installer to install a the demo application, I’m not able to install the Easy Installer a second time.
When I try to go into the recovery mode, the reset LED is blinking all the time.
And I’m not able to load the Easy Installer with recovery-linux.sh.
Is there any solution for this problem ?
Hello David_korn,
try to disconnect the USB connection. Put the device in recovery mode and then plug in the USB to the host PC.
Matthias
Thank you for your answer.
I tried this before but got no success in over 90%.
Never mind, I got now two brand new imX8 V1.0D and all works fine.
I guess the V1.0B is a “special” version.
Thank you for the update.
