Codesys Container CAN enabled?
Does the CAN bus interface work with Codesys Partner Containers? Can CANopen devices be connected via this?
Greetings @peregrin,
You’ll most likely need to customize your own container based on the Codesys container. Though it should be possible, please see the article here about using CAN in containers: How to Use CAN on TorizonCore | Toradex Developer Center
In general you’ll need to install some utilities like iproute in the container, so that you can enable/configure the CAN bus. These tools can just be added to the Codesys Container and CAN “should” work as long as you follow all the notices in the article I linked.
Though it should be noted the Codesys Container we provide is just a simple static demo. If you actually want to do something more with interfacing CAN and codesys then you’ll need to work on a actual solution. If you need help for this we have partners that specialize in such as listed here: Partner Demo Container - Codesys | Toradex Developer Center
