I am having an Ethernet issue with the Apalis iMX6Q on a custom carrier board with BSP 5.1.0-devel. The problem I am having is identical to this one that has no answer given. Basically I have built my custom Linux image and installed it onto the module. Everything works fine even after multiple reboots. However, when a hard reset is performed (i.e. power is removed and reapplied) the Ethernet module just seems to forever toggle from link up to link down.
[ 10.235370] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 10.263425] fec 2188000.ethernet eth0: Link is Down
[ 12.700608] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.723248] fec 2188000.ethernet eth0: Link is Down
This continues for seemingly forever. The only fix I have discovered is to reinstall the OS.
Any thoughts?
